The TRVs have changed with the latest firmware update.
You cannot control temperatures any more. Rather, you change the valve position.
@Phuturist Can you adjust the flow cards, details page and status indicator, please?
Happy to help with coding
This is not a firmware thing and nothing needs to change in the app. Just enable âEnable automatic temperature controlâ in the settings of the TRV.
Hi folks
I hope you are able to help me with some tips for this sticky situation.
Currently Homey does not discover my Shelly BLU door sensor - and I am not able to move the devices closers to each other without ruining the tape of the BLU unit.
The issue is that I already set up my Shelly BLU with the Shelly app (using a Shelly BLE gateway) where it works perfectly, so I then proceded to place it on the final location using the double sided tape that was supplied.
Then I opened Homey in order to pair it - and now I realize, that it seems that even though it is connected to the bluetooth proxy/gateway (which is connected to Homey), I still need to place the BLU door sensor next to Homey for them to pair using bluetooth⊠But since the BLU unit is already glued to the final surface - I now have a problem.
So the big question here is: Is there any way for me to pair the BLU device with Homey, which doesnât require me to ruin the double sided tape on the BLU device?
I can add that the distance between the BLU device and Homey is roughly 5 meters and the BLU device sits in the kitchen in an IKEA cabinet, where Homey is located in the living room - so an open door and/or a thin plaster wall is separating the rooms/devices.
The BLU door sensor works perfectly in the Shelly cloud.
Temporary move Homey closer to the BLU sensor?
Thanks for the suggestion.
Yeah, that could be a solution - I am just really nervous about moving Homey too much around.
The last time we had a power outage of about an hour, Homey and especially all Zigbee devices acted really strange for the next two weeks.
I noticed that some Shelly RGBW2 devices have double values.
Set as white device type:
Set as color device type:
One of the meter power capabilities is the total of all 4 channels but apparently doesnt show the correct description. Was this device paired recently?
Not sure why there are two dim levels shown on a channel of a RGBW2 white mode. If you want that fixed you will need to re-pair the device, wait 2 minutes and send me a diagnostic report afterwards. That might tell me more although logging on cloud is really limited and the information I need might not even be logged there.
It seems there is a bug with the RGBW2 and the duplicate dim whitelevels. Iâll change that with the next release.
No, this device was paired a long time ago. I will wait for a new version and then see what happens after the upgrade. Iâm waiting for a feature that re-pairing will not be needed anymore
Would it be possible to add an âthenâ-card for PM Mini, so that you could check the power consumption.
Hi
Not sure if its me or a bug but I have several Shelly 2 PM with detached switches. The switches are configured as button in the Shelly.
I want to use single/double/long press as a trigger in flows, but regardless if I press the left or the right button (input 0 or input 1) Homey will alarm input 0.
You need to use the token with the power usage and use that with a logic condition card.
Sounds like a bug. I will need to investigate. Is this on Homey Pro or Homey Cloud?
Homey Pro 2023, Version 10.2.1
The problem occured when i updated my flows to the new action-card. I used the generic one before, which was working.
Good morning,
I bought a Shelly PLUS UNI to count our water consumption. As sensor Iâm using a Heschen Typ PL-08N. Everything works fine when using the Shelly App.
In Homey I only get information about INPUT 1 but Iâm using COUNT IN on the Shelly PLUS UNI. I havenât found anything when going to settings to display COUNT IN.
Any recommendations or ideas?
Iâm using Homey Pro (early 2023)
Sounds like a bug. Could you post the output of http://shellyip/rpc/Shelly.GetStatus here using a code block.
Hi Jelger,
did you chanced something in the shelly homey app (regarding roller shutter / alexa) because now all my shelly roller shutters appeared in Alexa ![]()
This was a missing feature for a long time âŠ
Nope. Sounds like Alexa finally decided to support roller shutters.
Blockquote
{âbleâ:{},âcloudâ:{âconnectedâ:true},âinput:0â:{âidâ:0,âstateâ:false},âinput:1â:{âidâ:1,âstateâ:false},âinput:2â:{âidâ:2,âcountsâ:{âtotalâ:434,âxtotalâ:435.00,âby_minuteâ:[0,0,0],âxby_minuteâ:[1.00,1.00,1.00],âminute_tsâ:1706105480},âfreqâ:0.00},âmqttâ:{âconnectedâ:false},âswitch:0â:{âidâ:0, âsourceâ:âSHCâ, âoutputâ:false},âswitch:1â:{âidâ:1, âsourceâ:âinitâ, âoutputâ:false},âsysâ:{âmacâ:âA0A3B3670CACâ,ârestart_requiredâ:false,âtimeâ:â15:11â,âunixtimeâ:1706105481,âuptimeâ:60874,âram_sizeâ:245512,âram_freeâ:135332,âfs_sizeâ:458752,âfs_freeâ:143360,âcfg_revâ:33,âkvs_revâ:0,âschedule_revâ:0,âwebhook_revâ:0,âavailable_updatesâ:{},âreset_reasonâ:3},âwifiâ:{âsta_ipâ:â192.168.178.57â,âstatusâ:âgot ipâ,âssidâ:âFritzBox LWLâ,ârssiâ:-50},âwsâ:{âconnectedâ:true}}
Hope this works for you. I donât know how to create a code blockâŠ
Good enough. Itâs not really a bug but counts just havent been implemented yet. It will take me some time to add it to the app but I have added it to my todo list.
Thanks a lot! Looking forward for the implementation ![]()
