Auto update is On
Hello everyone,
I just received my Shelly Plus I4 modules and tested them. Couldnât find the settings for CoIoT in the web interface, but after a few minutes input 1 started working in Homey. But sadly only the first input seems to work, inputs 2, 3 and 4 donât seem to work. In the Shelly web interface I can see all the inputs working fine. Has anyone encountered this problem before and found a fix for this problem? A quick search on the forum and google didnât give me any results.
Thanks in advance,
Daan201
Sounds like a bug, Iâll look into it.
The notification of the old version is gone now for a few daysâŠ
Hello Phuturist,
Since your new update, all inputs are showing up now. Thanks! There is, I think, still a bug though. I canât seem to get the event based actions to work with the Shelly Plus I4. I just tested them with my Dimmer2 and they work perfectly. But I just canât seem to get them to work with the Shelly Plus I4. Tried the same flow but just edited the If card from the I4 event to the Dimmer2 event. So it is not the flow which is causing the problem.
Thanks in advance,
Daan201
Could you send me a diagnostic report, perhaps that tells me more on what is going on.
Is this what you need? This is new for me, but if there is anything else I could do to help, just ask! I am glad to help!
bd919939-2ffd-4b9c-ace2-4aa9c16b4b0f
Yes, I replied to the diagnostic report email.
Hmmm, the email is bounced. Perhaps the email address of your Homey account is not valid anymore. But this is what I responded.
The log is filled with connection errors with your i4. This indicates networking issues either in your own network or with the Homey network stack. Nothing about the action events though. Could you restart Homey, wait a minute or two, try and trigger a flow with the action event trigger card and send me another diagnostic report.
I will do that, I think I know why there are a lot of connection errors though. I am currently in a test setup at my parents house(where I currently live). The Homey + Shelly components are for my new home which is under construction. I have a plug connected in the socket and use some Wago connectors to test individual components (I measured the phase and zero connections so that it is connected correctly). If I switch between the dimmer2 or I4 I take the plug out of the wall to avoid an electric shock.
I restarted the Homey and did some tests. Here is the diagnostic report:
3c178021-e64d-4007-be53-5014c5c33327
Hope this helps,
Daan201
Checked my email just to be sure, still the one I use daily.
Still nothing in the log except for connection errors. When I have more time Iâll see if I can create a test setup to look into it. By just looking at the code I dont see any possible issues.
Hi @Phuturist
I seem to be having an issue using the Shelly PLUS 2pm in combination with my Homey. I am using the shelly PLUS 2pm to power two independent lights using the switch mode. I am able to turn both the lights on and off using the webinterface of shelly and by using the switch in the wall socket. After installing the Shelly PLUS 2 pm on Homey, two Relays are added as expected. When I hit the relay 1 button on the homey app, everything is working fine, light turns on and off. However when trying to turn on light 2 using the homey app the light wonât turn on, the relay 2 is not triggered (no click sound). When using the webinterface of Shelly I can trigger switch 2, the light changes to on/off BUT the homey relay button 2 also changes state. So although relay 2 seems to be receiving the right signals from the shelly PLUS 2 PM, it wonât push any updates to Shelly relay 2.
I have been running Shelly wallplugs, 1pmâs and PLUS 1pmâs without any issues.
Homey Pro (Early 2019) 7.3.0
Shelly App v3.9.4.
Thanks in advance.
Regards
Bas
A heads up, lotâs of people are using Unifi systems, Unifi have just released a new FW (6.2.13) to the EA channel with the following fix:
- [UAP-Gen2/3/4/5] Fix multicast issues affecting IoT device interoperability.
After upgrading to the previous FW (6.0.15) I was experiencing some connectivity issues with my Shellys, the famous connection error. These errors have disappeared after upgrading to the latest. Hopefully it is related so it is fixed. Just thought to share my experiences (itâs not always Homey / @Phuturist / Synologyâs fault
). Downside to this fw; a few people are experiencing unexpected reboots with their APâs, luckily iâm not.
Are you perhaps using device authentication (set a password for authentication)?
I am afraid that is the case for more mesh-systems. Asus has already released a beta-firmware for my XT8 mesh set that should fix problems with iot devices.
That fixed a lot of problems indeed, but my Shellyâs keep having connection problems with it.
When connected to my Fritzbox, all my Shellyâs work fine⊠![]()
Iâm going crazy.
I have a homey with shelly app. I have 7 shelly 2.5 on the roller of my house.
When I try to connect this 2.5 shelly to homey, initially for 2 seconds it works (see #1), but after, I get an error (see #2 e #3).
All shelly are update. Homey app version 6.11.2.893.
Some shelly have password e others withot.
Any ideas?
Do you Shellyâs work fine when operated from the webinterface of (Android/iOS) Shelly app?
Yes. All works with shelly app and with shelly.cloud.
Itâs a bug which Iâll try and fix with the next release.
