[APP][PRO&CLOUD][OFFICIAL] Growatt
New test version 1.0.3 is ready: Growatt | Homey
  • Added detection of type ‘inv’
That should fix it for you @Peter_Kawa
You’re the man, Robin
Working great here with energy too:
Got a 12 year old Growatt inverter, but wehn it was installed, I did not succeedto connect it to the Growatt cloud. Otherwise, I would be happy to help.
However, I only got solar panels, no battery.
I’ve a Growatt 1VZI9020A9 but not supported at the moment.
Need any input?
Yes, can you share your (temporary) login via DM?
works fine for me. Check if you are using latest version (1.0.2 at the moment)
da558c2d-ef43-4c46-ad3e-5c58b6a25562
Does not yet works for the 2500MTL-S convertor I have, installed 1.0.2 first and also tried 1.1.0 test version.
Convertor does works in the generic Solar panel app, which I have running on another homey.
You need the latest (1.0.2).
Get it here: Growatt | Homey
Are you sure you are installing the correct app? I do not see any diagnostic report from you.
f34bb601-ff2b-4250-8e30-b0b192589d3b
Yes, I think so.
Ok, i did not. Very handy to have 2 apps with same name in the store :smiley:
It works.
nope, nothing received. You must be using the wrong app.
Hi Robin,
I’ve installed your new app and added my inverters and all is looking good. One question though, the ‘old’ app (Zonnepanelen by Diederik) showed the daily energy while your version shows the total energy during the whole lifetime of the system. Personally I’m more a fan of showing the daily production, is it possible to add this?
(My Goodwe Inverter shows Generation Today, Generation Month and Generation Total, next to Energy and all is displayed good in Homey Energy Dashboard)
Don’t know if you still need testers, if so, let me know. I’ve got 2 Growatt 3000TL3-S inverters.
v1.0.3 is ready for testing: Growatt | Homey
  • Added Energy meter for today and this month (@DaneedeKruyff, specially for you!)
  • Polling fixed setting 1 minute.
  • Better error message display for UI.
  • Added additional logging during pairing.
This version will likely be certified as stable release in the Homey app store.
Note: to see the new energy meters, you must delete and re-pair your inverter.
Only for Battery owners. The inverter driver is already tested well.
@RM_de_Gruijter
I have a MOD 8KTL3-XH inverter with 1 APX 98020-P1 BMS and 2 Growatt APX HV and SYN 50-XH-30 Backup boks
If you would like to test.
However I have a small problem. I can add the new Growatt app 1.0.3, but it is not showing up whan I want to add a new device?
That is why I need your help. See DM.
new version 1.1.0 is ready for testing: Growatt | Homey
  • Added inverter detection for type ‘tlxh’.
  • Added Meter driver.
  • Added Battery driver.
@RM_de_Gruijter Adding inverter fails. I don’t get any error message, just a no new device found after entering user and password. MOD 10KTL3-XH BP and APX HV battery system
And btw so happy to se an official homey app for growatt looking forward to be able to see charge status.
Can you send an app diagnostics report after trying to add a device?
You are not using the latest test version. You need 1.1.0 (link on first post)
