Version 4.1.8 Homey Pro 2023 version 13.2.0
Pls re-install the app. Here I have the same installation and no problems.
Wrong location could be a reason.
For my location in the middle of The Netherlands it seems to be okay.
Hi. Of If I change to Groningen it returns different values. Setting at Leiden (close by) gives same values as Oegstgeest. Reinstalling breaks many flows, huge time effort. Hope there are other options to fix this.
NO worries, i understand the need for more information if the diagnostic has 0 info in it. I was able to solve the issue without reinstalling. (Homey cloud user at the moment)
go to app settings
change location to any other city in the country
refresh the data via the button
change location to your own city again
Refresh the data via the button
Magic! no need to reinstall the app
@Woltie_r A reinstall does not affect your flows. You should not uninstall and then reinstall the app.
If there is a update of the app you also have not to repair anything.
Hi Mike, how? I can deinstall the device but that gives me broken flows. Restarting the app didn’t work.
Adding new device gives me the same values.
Install the app like you did it the first time. Go to the Homey app page, select the KNMI app and click on Install.
The app will be installed on Home] again. If there was a problem with the app, it is now installed like the first time.
All the flows are still working.
Thanks a lot. Did reinstall yesterday but today still giving me low values. Today max 18 degrees where 23 is predicted.
I have no idea why the app is not working as suppost to be.
Hi how can I use the “AND” flow card “De huidige temperatuur is” to fire true if the temperature is HIGHER then the given number ??
now it has to be exactly the number,
thats perfect! thx
Yesterday and today i got 3 messages from KNMI on my timeline. It says "if you are an existing user, you need to check your flows above version 4.1.0! see the app topic and then a link to this forum.
This is for me. But wehat should I check? In my flows I use KNMI as a trigger or as a logic/variabel.
PS when you go the app in Homey, under flows it only shows flows that use KNMI as a truigger. Not the ones that use the logics/values.
Korturl gose to [APP][Pro][Cloud] KNMI - #587 by LRvdLinden
I don’t get how and when data is refreshed …
Can somebody please comment:
- every 10 min. new data is fetched automatically, and when it changed it will trigger a when cards like “When current temperature is changed”
- I can force a refresh by executing a then card “fetch new data” This should trigger the When cards “when … is changed”
I see that both methods do work, but not always (once every few hours). I can see weerlive.nl that the latest data is still not visible in homey (hours later).
Manual pressing the “nieuwe knmi data ophalen” does work immediately. The latest data from weerlive is instant visible and triggers my when-cards.
Where does this go wrong? (I did read all the posts and explanations about this app, but I miss a basic understanding when en how data update and trigger process works.
Thanks.
Can the timeline spam be removed that shows with restarting please
