When selecting tags they are different in local tags and device tags. For example “Huidig weeralarm” and “Weeralarm titel” is not available in local tags.
Any idea why this happens? app seems to work anyway, at least the “when it starts raining” trigger.
Settings - Timeline - KNMI
Then disable KNMI to write to timeline ?
Thanks for the suggestion, but that option isn’t there.
At least it “automagically” stopped posting every 10 minutes now, really don’t know what that was about and I did not change anything.
The option is there in my app…
Thanks! This helps a lot, does the knmi still work in between the “offline” messages?
Would it be possible to add a card where you manually input the wind direction (degrees, or via N/NW/E/etc)? I want to combine a wind direction from the West in combination with a temperature of below 3 to 4 degrees Celsius, since that combination will most likely result in frozen car windows.
You can do it whit the standard cards in Homey
@LRvdLinden I have sinds a day or so every 10 minutes the message that the KNMI App is offline in the timeline , it seems to work fine.
Anny idea how to fix this?
I have no option to disable the writing to the timeline.
Update: I found where to disable the timeline messages, but still strange all the offline messages.
Same here KNMI offline all the time and lots of Timeline messages.
Where did you deleted all those messages because there is no option in the Timeline app for KNMI .
Happy New Year to all of you.
Best regards Peter.
Hi, you have to go to: Homey → Settings → Timeline → and then choose the App.
Here you can disable it.
I hope there comes a fix for the error messages, because this is not a solution for the problem ![]()
Hi Paul,
Thanks for your quick reply, and I looked already @ settings timeline but there’s no specific field for KNMI to disable messages here, it’s only possible to disable all the messages but that’s not what I want.
Best regards Peter.
So I’m having the same issue. Where have you found to disable the timeline messages? Or do you indeed disable ALL messages. (Somewhat the same effect as simply not taking a glance at the timeline.)
Ah sorry, found it.
7 Hours ago latest KNMI update, even after app restart.
What could be done to make the data more reliable?
Edit: it seems that the Weerlive site has problems updating.
Thats your answer ![]()
