I have this since the last update, somebody else have this problem?
Read the changelog ![]()
Yes is see the message above, i need to change my flow.
Thnx!
Waiting for the automatic update to see what I have to change for putting my flow(s) here.
For now some experiences I found.
The “weeralarm bericht” can be, and is now, empty.
There can also more then one colour in the message.
For more colours in the message see flow in changelog.
With no weather alert the alert message is always empty in the API ![]()
Not always, I found out.
You mention it in your flow. (P 180)
Variables.
The colours: Y/N
“Weeralarm bericht !”: Text.
Due to the unwritten rule “no action if it is not necessary”, I adjusted my first design.
The advantage now is that the Yes and No lines are easy to follow.
Here in detail how the time line notification is made by using spaces.
The extra line is Shift + Enter.
For information.
By further testing I found out that the KNMI 2.0 tag “Status server” give “offline”
That’s strange because the 2 temperature that I used is coming in normally.
An simple timeline notification with that tag in it shows it directly.
It may be that the api was briefly unavailable. The app then displays a notification when offline after 1 min.
It’s at least 2 days.
The variables that I hook to it shows, on my dashboard tile, the offline from the beginning.
So I did the timeline test. Even now “offline”.
Do you use the token? Do you have a example?
For information.
The “Weeralarm bericht" is already changed for tomorrow.
Flow has worked well.
Thanks KNMI … NOT
The flow can now in the trash-bin.
Because we have only the pictures to look for the code colour.
In 1969 a man on the moon. But this is practically impossible.
Therefore my KNMI canvas is switched offline for the rest of the month.
Including all the test flows.
Only 2 temperature flows are copy/paste to an other canvas.
@Theo_de_Koning @B-J_Soecker So again, the api only indicates whether there is an alarm or not. You can of course say in your flow: there is an alarm → send alarm text and image.
So again: That of the API I know.
There are now no colour codes in the alarm text.
So we have only the “Yes or No alarm” and the images.
In the text stays only where it is, and some numbers that saying me not mutch.
When there are again 2 type of alarm? You NEEDED the images.
The images I see them for weeks the whole day.
When it’s going from yellow to orange to red and back.
No new trigger.
Solution: (edit)
The KNMI have to go back to “Code [Colour]” for TODAY only.
Unfortunately that is not supported. Otherwise I wouldn’t have modified it or changed it back.
