Deprecated
See [APP][Pro] Chipolo - #12 by smarthomesven
Note that the app probably doesn’t work anymore. However, you can still download it from here if you want to try the app.
Chipolo app for Homey
Note: the connection state indicated in the Chipolo device is the connection state to your phone. Homey doesn’t connect to your Chipolo devices directly as this would break mobile app functionality.
You can also use this app to ring your phone and view its battery status (you don’t need a Chipolo device for that functionality, only the Chipolo mobile app)
Device support
This app only supports the older Chipolos (One, Card, Classic and maybe the POP series).
Chipolo SPOT and Chipolo Point are NOT supported!
Oops, seems like the app’s polling is a great way to get blocked/rate limited by Cloudflare
I’ll have to reduce the polling frequency I think, and maybe also fake the User Agent
Just added a fix for Cloudflare’s IP bans, should all be good now.
End of maintenance announcement
This app won’t be getting any further updates since Chipolo has implemented Cloudflare protection that blocks access from Homey. This is not possible to circumvent, since Cloudflare has advanced bot protection checks in place that this app will fail.
I also see that nobody was ever able to add a device, which is probably because of the bot checks.
I’d like to thank everyone for their support in testing the app.
