[APP][Pro] Broadlink App
Will do!
Homey and Broadcom are on the same network. The only one I have (Asus mesh).
This is the log after Restart of your App:
a4bcd96c-5bcc-4db0-ad04-a90809143b16
Only thing that changed in my network is that I have removed Pi-Hole and set DNS in my router to Adguard.
Mind you, both Homey and Broadcom App work fine.
Update
I switched dns to Google. Same time out in Homey with broadlink communication
You said you changed nothing :wink: … you can try to diagnose eg. installing Netscan and trying to check availability of RM4Pro from / via Netscan, I suspect that Homey can’t connect to your RM4Pro exactly because of that reason. Sorry, can’t help more here.
Sorry I forgot about the DNS. I thought it was not relevant, as everything works fine.
Will do more testing tomorrow.
DNS might not be relevant as you are using IP - but I guess that RM4Pro might need to be connected to the cloud and that could have been broken…not sure here.
I removed RM4Pro from Homey. Added it again, the ip had not changed. Learned a RC command and…it works again.
Weird…but good to know that this will solve the issue.
Hmm, can you send again the log? That’s not usually behavior, eg. I have my RM4Pro set already for a year and still works fine…
Here it is:
9f57629a-db30-49b0-bdc5-1e8e336d32e1
Sorry, logging was off.
c73933a7-099f-48a7-aee5-edf0973bc691
First logs showed 192.xx.x.18, the new logs shows 192.xx.xx.22 … seems you do not use static IP address for RM4Pro, please check your settings.
Damn, if that is the case I should aplogize…
I can’t believe the IP changed when the time out started. All ip’s in my LAN are given with a long lease. Only after I removed the device and added a new one (which makes sense, with the IP lease in my router) a new IP was assigned.
Anyway… it is working again. And I have to thank you for the quick response!
I would love to buy you a coffee/beer!
You would be then the first one in last 40 days or so and 3rd one in last 3 months :rofl: But yes, it is.
You might be able to buy both if the place is not too classy :wink:
Done!
Thanks again!
Confirmed! All of my 315mhz stuff is working fine with the RM4 Pro in combination with Homey. :+1:t2:
Might seem obvious, Bretislav, but just to make sure: is the Homey > Broadlink device connection completely local?
(not like Homey’s “localness” which needs internet every other week)
Thank you!
Well Peter, at least I can say that this app is Local only solution (Homey ↔ Broadlink) but devices shall be setup using the Broadlink mobile app. Also I remember I read somewhere that some devices have problems afterward, if not Cloud connected (Broadlink device ↔ Cloud)…
Thanks!
Just FYI, For a new LED light device, I’ve learned it’s IR signals using Homey and your app, it’s not added as a device in the mobile Broadlink app.
Appguard shows regular low interval checks with these URLs
Time
Request
02:00:44
4374v2tcp.broadlink.com.cn
02:00:44
02:00:44
4374v2backup.broadlink.com.cn
02:00:44
4374v2main.broadlink.com.cn
02:00:44
02:00:44
02:00:17
24374activ.ibroadlink.com
02:00:16
02:00:16
02:00:16
02:00:16
02:00:16
02:00:16
02:00:16
16:19:26
16:19:26
16:19:26
16:19:25
16:19:25
I"ve now blocked broadlink.com.cn & ibroadlink.com (and their subdomains), to see what happens :person_cartwheeling:
hello, does the rm4 mini also support temperature and humidity in the homey app ?
i see some users having that, but ive not seen it for the rm4mini. tia
It’s for RM4 Pro version only, I think RM4 Mini doesn’t have this functionality.
No it doesn’t have this function in homey but it does on the Broedlink app . Would it be possible to implement it in homey :thinking:
I have RM4 Mini myself and it’s not provided even in the officiall app.
