Hi everyone,
I am a brand new Homey user and developer. I’ve developed a new app called Bridgekeeper and I’m looking for testers.
I wrote Bridgekeeper to address the need for manually overriding automation. It supports a Shield device driver that can shield a peer device from cooperating animation. For example, lighting automation that turns off the light when I don’t want it to can be manually overridden by physical interaction with the light switch to turn it back on.
Along the way it was simple enough to add a Clone device driver that creates a virtual clone of a peer and a Link device driver that can be used to make a device (virtually) appear to be in multiple zones.
Thanks for your support!
Bridgekeeper provides Clone, Link and Shield virtual device drivers.
Each such virtual device
- Is paired with a user-selected peer device.
- Assumes the class and system capabilities of its peer.
- Remembers its peer to bridge the flow of capability values.
- Copies the values from its peer when first added.
Clone
- Behaves as a virtual device just like its peer but detached from it.
Link
- Allows capability values to flow freely to and from its peer.
- May appear in a different zone than its peer.
- Allows a door sensor between two zones to trigger activity in each.
Shield
- Shields its peer from cooperating automation.
- Allows values to flow to its peer only when the shield is off.
- Copies values from its peer when the shield is toggled.
- Provides shielding mechanism but not shielding policy.
Shielding policy is supported by
- Listening for peer value changes.
- Publishing capabilities that have drifted.
- Triggering policy flows on capability drift.
Shield example
Manually override Light automation by physical interaction with its onoff switch.
Rewrite automation such as this
- When Light’s zone is active/inactive, Then turn on/off Light
as
- When Light’s zone is active/inactive, Then turn on/off Light Shield
- When Light Shield onoff drift is detected, Then toggle shield on or off.
where Light is Light Shield’s peer.
