Maybe you could change the title of this forum and app logo to Awtrix 3 and NG. Awtrix light was the name of the software several generations ago.
I have fixed Awtrix3 issues with power of AI too… ![]()
Regarding name, the name of app is awtrix light, i cant change it sadly, but in forum i can try to add some info to it…
In the app store I only see the name Awtrix with image Awtrix light. The forum title is too long now.
/critical mode off
[HOW-TO][Pro] Repairing Flows after migrating from AWTRIX Light to AWTRIX NG
Based on Martijn Poppen’s original Flow-repair script, I prepared a customized HomeyScript to make migration from AWTRIX Light to AWTRIX NG easier.
Martijn’s script is excellent when a device is removed and re-added while the replacement exposes the same Flow cards. In that situation, replacing the old device UUID with the new UUID is sufficient.
AWTRIX Light to AWTRIX NG is slightly different:
- The device UUID changes.
- The old AWTRIX Light Flow card IDs are not always available for AWTRIX NG.
For example, an old card may contain:
homey:device:<new-device-id>:notificationIcon
After migration, AWTRIX NG uses:
The message, icon, color, and duration arguments are compatible, but the Flow-card ID is different. Therefore, replacing only the device UUID still leaves the Flow card unavailable or displayed as card: null. This could be addressed in the app code, but changing or remapping existing Flow cards would require additional backwards-compatibility safeguards. It would also not automatically repair Flows that were already stored in the broken format. For users who have already migrated, the customized script performs both operations:
- replaces old device UUID references in regular and Advanced Flows;
- changes the legacy
notificationIconcard to the NG-compatiblenotificationcard; - supports flows where the UUID was already replaced but the old card ID remains;
- provides a soft-run mode so changes can be reviewed before applying them.
For an already completed UUID replacement, use the same UUID in both arrays and keep softRun = true first:
const oldIds = [
'NEW_DEVICE_ID',
const newIds = [
'NEW_DEVICE_ID',
const softRun = true;
The script does not send commands to the display. It only updates stored Flow definitions. Nevertheless, use it carefully:
- verify the device IDs;
- run a soft-run first;
- review the output;
- set
softRun = falseonly after confirming the planned changes; - test one repaired Flow afterwards.
This is specific to the AWTRIX Light → AWTRIX NG migration. The UUID replacement logic is generic, but the notificationIcon → notification mapping should not be reused for unrelated apps.
An app-side compatibility change could theoretically keep the legacy card available for NG devices, but that would not automatically rewrite already stored Flow JSON. The one-time migration script is therefore useful for repairing existing Flows without recreating them manually.
The customized script is included below.
The original Flow-repair approach is documented by Martijn in the Homey Community thread.
// HomeyScript: AWTRIX 3 -> AWTRIX NG Flow migration
const oldIds = \[
'37614016-25f4-48e6-95a7-d9221361d7fa',
const newIds = \[
'1cca7b6e-f9c9-493e-827e-879afd423db0',
// true = allow oldId === newId for auditing already-replaced UUIDs
const allowSameId = true;
// true = preview only; false = write changes
const detailedLog = true;
// AWTRIX 3 legacy card -> shared AWTRIX/NG card
const ACTION_CARD_MAP = new Map(\[
\['notificationIcon', 'notification'\],
if (oldIds.length !== newIds.length || oldIds.length === 0) {
throw new Error('oldIds and newIds must have the same non-zero length.');
const migrations = oldIds.map((oldId, index) => ({
oldId,
newId: newIds\[index\],
for (const { oldId, newId } of migrations) {
if (
!oldId
|| !newId
|| (oldId === newId && !allowSameId)
throw new Error(\`Invalid migration pair: ${oldId} -> ${newId}\`);
function deepReplace(value, from, to) {
if (typeof value === 'string') {
const parts = value.split(from);
return {
value: parts.length > 1 ? parts.join(to) : value,
count: parts.length - 1,
if (Array.isArray(value)) {
let count = 0;
const result = value.map((item) => {
const replaced = deepReplace(item, from, to);
count += replaced.count;
return replaced.value;
return { value: result, count };
if (value && typeof value === 'object') {
let count = 0;
const result = {};
for (const \[key, item\] of Object.entries(value)) {
result\[key\] = replaced.value;
return { value, count: 0 };
// Supports normal Advanced Flow cards and the diagnostic shape:
// { card: null, data: { ... } }
function storedCard(card) {
return card?.data && typeof card.data === 'object'
? card.data
: card;
function belongsToDevice(card, deviceId) {
const data = storedCard(card);
const deviceUri = \`homey:device:${deviceId}\`;
return \[
data?.ownerUri,
data?.uri,
data?.id,
\].some((value) => (
value === deviceUri
|| value.startsWith(\`${deviceUri}:\`)
function migrateActionCardId(card, newDeviceId) {
if (
!data
|| typeof data.id !== 'string'
|| !belongsToDevice(card, newDeviceId)
return null;
for (const \[oldCardId, newCardId\] of ACTION_CARD_MAP) {
// Regular Flow card: id = notificationIcon
if (data.id === oldCardId) {
data.id = newCardId;
return { oldCardId, newCardId };
// Advanced Flow card:
// id = homey:device:<uuid>:notificationIcon
const suffix = \`:${oldCardId}\`;
if (data.id.endsWith(suffix)) {
data.id = \`${data.id.slice(0, -suffix.length)}:${newCardId}\`;
return null;
function migrateCard(card, location, details) {
let updated = card;
let changed = false;
let uuidReplacements = 0;
for (const migration of migrations) {
// Same-ID mode is an audit/card-repair mode.
// Do not count same-ID strings as replacements.
const replaced = migration.oldId === migration.newId
? { value: updated, count: 0 }
: deepReplace(
updated,
migration.oldId,
migration.newId,
updated = replaced.value;
if (replaced.count > 0) {
changed = true;
uuidReplacements += replaced.count;
if (detailedLog) {
details.push(
\`${location}: UUID ${migration.oldId} -> \`
+ \`${migration.newId} (${replaced.count})\`,
// This also runs when UUID replacement already happened earlier.
const cardIdChange = migrateActionCardId(
updated,
migration.newId,
if (cardIdChange) {
changed = true;
if (detailedLog) {
details.push(
\`${location}: card ${cardIdChange.oldCardId} -> \`
+ \`${cardIdChange.newCardId}\`,
return {
value: updated,
changed,
uuidReplacements,
function migrateRegularFlow(flow) {
const updated = JSON.parse(JSON.stringify(flow));
const details = \[\];
if (updated.trigger) {
const result = migrateCard(
updated.trigger,
'trigger',
details,
updated.trigger = result.value;
changed ||= result.changed;
uuidReplacements += result.uuidReplacements;
for (const section of \['conditions', 'actions'\]) {
if (!Array.isArray(updated\[section\])) continue;
updated\[section\] = updated\[section\].map((card, index) => {
card,
\`${section}\[${index}\]\`,
details,
return result.value;
return {
updated,
changed,
uuidReplacements,
details,
function migrateAdvancedFlow(flow) {
for (const \[key, card\] of Object.entries(updated.cards || {})) {
card,
\`cards.${key}\`,
details,
updated.cards\[key\] = result.value;
return {
updated,
changed,
uuidReplacements,
details,
async function main() {
console.log('======================================');
console.log('AWTRIX Flow migration');
console.log(\`Soft run: ${softRun}\`);
console.log(\`Allow same ID: ${allowSameId}\`);
console.log('Card mapping: notificationIcon -> notification');
let regularPlanned = 0;
let advancedPlanned = 0;
let successfulWrites = 0;
let failedWrites = 0;
// Regular Flows
const flows = Object.values(
await Homey.flow.getFlows(),
for (const flow of flows) {
const result = migrateRegularFlow(flow);
if (!result.changed) continue;
regularPlanned += 1;
console.log(
\`\[regular\] ${flow.name || flow.id}: planned\`,
if (result.uuidReplacements > 0) {
console.log(
\` UUID replacements: ${result.uuidReplacements}\`,
if (detailedLog) {
result.details.forEach((line) => {
console.log(\` ${line}\`);
if (!softRun) {
try {
// Send only mutable regular-Flow sections.
const partial = {
trigger: result.updated.trigger,
conditions: result.updated.conditions,
actions: result.updated.actions,
await Homey.flow.updateFlow({
flow: partial,
successfulWrites += 1;
console.log(' Written successfully');
} catch (err) {
failedWrites += 1;
console.error(
\`\[regular\] FAILED ${flow.name || flow.id}:\`,
err?.message || err,
// Advanced Flows
const advancedFlows = Object.values(
await Homey.flow.getAdvancedFlows(),
for (const flow of advancedFlows) {
const result = migrateAdvancedFlow(flow);
advancedPlanned += 1;
console.log(
\`\[advanced\] ${flow.name || flow.id}: planned\`,
console.log(
if (detailedLog) {
if (!softRun) {
try {
// Preserve the complete Advanced Flow.
await Homey.flow.updateAdvancedFlow({
advancedflow: result.updated,
} catch (err) {
failedWrites += 1;
console.error(
\`\[advanced\] FAILED ${flow.name || flow.id}:\`,
console.log('Summary');
console.log(\`Regular flows planned: ${regularPlanned}\`);
console.log(\`Advanced flows planned: ${advancedPlanned}\`);
console.log(
\`Successful writes: ${softRun ? 0 : successfulWrites}\`,
console.log(\`Failed writes: ${failedWrites}\`);
main().catch((err) => {
console.error(
'Migration failed:',
Output example :
[regular] Postbox movement closed doors: planned (4 UUID occurrence(s))
actions[11]: UUID 37614016-25f4-48e6-95a7-d9221361d7fa -> 1cca7b6e-f9c9-493e-827e-879afd423db0 (2)
actions[11]: card notificationIcon -> notification
actions[12]: UUID 37614016-25f4-48e6-95a7-d9221361d7fa -> 1cca7b6e-f9c9-493e-827e-879afd423db0 (2)
actions[12]: card notificationIcon -> notification
[regular] Pohyb v rozvodné skříni domu: planned (2 UUID occurrence(s))
actions[5]: UUID 37614016-25f4-48e6-95a7-d9221361d7fa -> 1cca7b6e-f9c9-493e-827e-879afd423db0 (2)
actions[5]: card notificationIcon -> notification
[advanced] Developer check - nr of install app - adv: planned (0 UUID occurrence(s))
cards.fb2ebb67-c354-4a5e-9284-bf14163daab8: card notificationIcon -> notification
cards.518ea370-18cf-41e5-8f29-612c330f52fb: card notificationIcon -> notification
[advanced] HaasSohn check prior to the non-working day adv: planned (0 UUID occurrence(s))
cards.d888d61a-61ea-42ee-8604-861bc2ae8474: card notificationIcon -> notification
cards.1f7cf32e-9e65-41c3-93a7-c47fc55ca96d: card notificationIcon -> notification
cards.069f64fd-464c-4dbf-b625-f36ba74e34ea: card notificationIcon -> notification
cards.edb4573a-9c4b-462c-a8eb-ef388fd4733f: card notificationIcon -> notification
[advanced] Weather alerts activated, storm - adv.flow : planned (0 UUID occurrence(s))
cards.3c31bfff-8276-4f03-bdee-95cef174401b: card notificationIcon -> notification
[advanced] AWTrix light Simon room adv: planned (0 UUID occurrence(s))
cards.64f371e9-af66-47ed-8f26-1322e323cca1: card notificationIcon -> notification
cards.b8d3418d-9eba-43dd-aa1b-94eb95157488: card notificationIcon -> notification
cards.952b3e49-0eda-4d48-9e83-11362eecb928: card notificationIcon -> notification
cards.600ca871-7b3d-47ae-98b5-0abda2a46cb1: card notificationIcon -> notification
cards.df780320-7d5a-4cdc-99ad-176d5e313a4e: card notificationIcon -> notification
cards.04098c11-f475-4637-97c9-1697c37bc2a2: card notificationIcon -> notification
cards.e939bcf3-9eab-4e0e-8483-8ba6f833a891: card notificationIcon -> notification
cards.e03fb580-97cc-42c9-aacf-758b7fcce599: card notificationIcon -> notification
cards.160626c8-b0f8-4616-851b-926595db8b15: card notificationIcon -> notification
cards.3b7f2b5a-3387-4fed-9b01-4cd7f948b60c: card notificationIcon -> notification
cards.0b574371-4df0-4f11-b3b8-7ebd99e33acc: card notificationIcon -> notification
cards.3121aca1-e3e4-407c-a0ec-ada139d269a8: card notificationIcon -> notification
cards.1e2f4abd-18a7-400b-b9b2-5493fb4e08f8: card notificationIcon -> notification
cards.f20517c5-05ab-4446-ae8e-3ec8badf0090: card notificationIcon -> notification
cards.901e08fa-81fd-46ab-957f-eb81e5e95667: card notificationIcon -> notification
cards.59ee56e2-a6c9-48f1-8f26-2edaa7844013: card notificationIcon -> notification
cards.ebb212e2-7a65-4d8a-8a32-b364b45540c8: card notificationIcon -> notification
cards.cd74ef2f-66ae-4397-ad39-6acd1c15823f: card notificationIcon -> notification
cards.a00b0b28-45db-4549-a81a-3728fe24c123: card notificationIcon -> notification
[advanced] AWTrix notifications: planned (0 UUID occurrence(s))
cards.b6fc60f1-388c-4bcc-a09e-34f9487d7a8d: card notificationIcon -> notification
cards.3df5f31a-7884-4a92-b570-577f1849f4e4: card notificationIcon -> notification
cards.847e03b9-a1e5-43ad-a30b-92dfe184a643: card notificationIcon -> notification
cards.0ad352f8-e537-407a-836d-e7028111d6c0: card notificationIcon -> notification
[advanced] Doorbell rang - adv (nonAthom): planned (0 UUID occurrence(s))
cards.d1adc972-73cc-4ec5-8090-7cff77f56458: card notificationIcon -> notification
[advanced] MKubeska YouTube adv: planned (0 UUID occurrence(s))
cards.9158f02e-183e-4ead-8dc3-81d39bdc0423: card notificationIcon -> notification
[advanced] HaasSohn checks adv (Advanced Scheduler): planned (0 UUID occurrence(s))
cards.de70a46c-6ebd-4d66-a7e6-f4ca4e3e9b96: card notificationIcon -> notification
cards.893a09c8-dea3-4271-b0a3-496f9dd1e836: card notificationIcon -> notification
cards.6dd15f03-b5fd-492f-991c-30a28d29a9de: card notificationIcon -> notification
[advanced] Water pressure calculation adv: planned (0 UUID occurrence(s))
cards.1f5a6548-53ec-49d9-85ab-c6c645bff37d: card notificationIcon -> notification
cards.7fe20785-b3ed-4834-9d57-90d162e3caf4: card notificationIcon -> notification
cards.d8855cd9-ce7c-4083-b05c-54a2a23af312: card notificationIcon -> notification
cards.77de0cb7-969a-4cbf-ba24-dd3835c4fc23: card notificationIcon -> notification
cards.c76e39b5-7e48-40b6-83bd-be9f14273242: card notificationIcon -> notification
cards.a2603d68-a70e-4586-84d3-e65d9182513e: card notificationIcon -> notification
cards.7e1fd0cf-72f7-4d09-981f-c0f9ecb90006: card notificationIcon -> notification
[advanced] Movement in front of house Eufy adv: planned (0 UUID occurrence(s))
cards.e984d301-c74c-4dda-982c-06029e58ed8f: card notificationIcon -> notification
[advanced] Airplane tracker OpenSky, Flightradar adv: planned (0 UUID occurrence(s))
cards.33120d80-8a4a-4201-826c-54f296d9fdff: card notificationIcon -> notification
[advanced] Pračka susička změna stavu adv: planned (0 UUID occurrence(s))
cards.215f3404-e317-4543-8530-1466ed7c23eb: card notificationIcon -> notification
cards.fc26b0f5-0323-47fe-915e-706ef9776efd: card notificationIcon -> notification
cards.96b2d7aa-9989-4898-ac5e-d6f95dd8de67: card notificationIcon -> notification
cards.db8440ed-3748-4f9c-8a97-a31d6f55b670: card notificationIcon -> notification
--- Summary ---
Regular flows planned: 2
Advanced flows planned: 12
Successfully written: 14
Failed writes: 0
Soft run: false
Thanks for creating this script, @Sharkys! If only I waited a little longer before migrating my AWTRIX 3 flows to NG manually…
One small side-note: next to the flowcards also many of the JSON keys and values have changed. This means that I you are using flowcards in which the JSON field/parameter is populated, you’ll have to check and update those manually. On the positive side: this requires you to look at the new and very elaborate documentation of AWTRIX NG and learn/get an understanding of the new commands and syntax, which I personally found very valuable.
Yes, for some functionality there is a ready-made card available.
I mostly use the app and notification cards. If you want to control/manipulate the displayed text a little bit more then just the color and icon, then additional JSON-parameters are needed. Which is great because you can customize the text like you want.
For example I have a flow that creates/updates an app that shows the current weather alarm info (if any). It shows the weather alarm code (yellow/orange/red) in the color of the alarm code followed by the alarm’s info in white (so colored text fragments). Also the behavior of the icon and to show a longer message in full (instead of switching to the next app mid-way when the default app duration expires) requires additional JSON-parameters.
Similarly for e.g. displaying the album/artist/track info of the currently playing song in full (which is a longer text) requires additional JSON-parameters. I use an app for that as well as a notification that displays the new info when a track changes.
Note that this was also the case for the AWTRIX 3 flow cards. So I used the JSON parameters already for manipulating the text.
Yeah, i could make bc compatible layer
sorry for that… my goal was to make new driver as much clean as possible. but we could try to put this migration to AI to write it even with json option changes, and yeah now i belive all json options are available ![]()
but if you miss some functionallity, write me, i will add it ![]()
Btw, if you want entire text no matter how long it is, give it json option: repeat: 1
It will display the entire message once, no matter of time set to display message
Yes, that is exactly what I am using
I am not missing any functionality (except the battery percentage we talked about in an earlier post).
By the way: I think your choice to offer basic flowcards for creating an app or notification and a more advanced version of each that allows you to add JSON-parameters is perfect. Keep it simple by default and offer the option to create fully bespoke apps/notifications for more advanced users
FYI, I have submitted PR for that.
I know, merged, released to test branche… ![]()
i see it too, already have fix… battery_measure add some issues i did not expect… so i need to clean code a bit… Athom explicitly forbids to have battery_measure and lowBattery… Issue is, not all awtrix need to have battery, so im thinking how to do it without compromising anything…
battery_measure explicitly requires battery type in manifest, we can put here internal, but what if device have no battery? Low_battery only was easier
you could simply ignore it if battery was not present…
Fix released to test: 2.2.3
Any issues with 2.2.3 so far? if not, i would like to push it to release…
I haven’t come across any issues in my setup
I think I found a bug after all ![]()
If I try to play a melody on the buzzer, the flowcard errors out with an unknown route error.
I first though that I might have to save the melody in AWTRIX NG’s web interface (Audio section) and then call the melody by its name in the flowcard, but that gives the same error.
Playing the melody directly from AWTRIX NG’s web interface works just fine.
You are on 1.1.0 awtrixng? I saw blueforcer did some changes regarding buzzer, i need to check it…
Yes, the device is on AWTRIX NG firmware 1.1.0.
