[APP][Pro] AWTRIX - Connected Smart Clock for your Smart Home
Indeed!
@elsinga: In addition to a backup, you also have the option to export (and import) your flows.
I already thought of getting Homey Backup, so this is the moment. :wink: Exporting flows I already looked at, but when my Homey Pro would crash then all the UUID’s of the devices would change and the flow would not work anymore (all flow cards would point to unknown devices). Exporting is nice when you are going to change a flow massively, but is not a backup IMHO.
Thanks for your help so far! Still baffled about what happened…
Fully agree. Hence I indicated that it would just be an additional safeguard. Note that there is a script available to change those changed devices IDs to the original ones. But of course, this all requires effort. Restoring a back-up, if possible, is the better option.
How do I disable or delete internal/system apps like clock, humidity etc,
I just want my own app to be displayed all the time. I update the app every 2 seconds to show the amperes of L1 L2 and L3 of my P1 meter.
In app settings you can disable build-in apps, but im not sure if you can disable all of them… as homey do not persist apps to internal memory of awtrix (to limit writes of internal memory, it have limited ammount of writes like ssd, jist really really less), but if you create permanent app via api, and then update it thru homey it should work
I cannot find that app settings.
When creating a custom app I use duration: 600 and whilst updating the screen every 1 second that seems to prevent the other apps to appear. However I fear that after every 600 seconds all internal apps appear each for 10 seconds, before my own app appears again for 600 seconds.
Here it is, in advanced settings… just turn off the toggles
Thanks, It is in the device tile of the clock. I did found it.
Much easier as programmatic, see JASON Properties in AWTRIX 3
Should you have the AWTRIX 3 mobile app, then you’ll find similar toggles to enable/disable the built-in apps over there:
Yep, just in settings of homey as usuall :slight_smile: forget there is web version, automated everything
Hallo !
Das Ulanzi Display ist zwar unschlagbar billig, aber scheinbar auch von minderer Qualität gegenüber der LaMetric Clock. Anfänglich hat alles funktioniert, aber bereits nach einigen Monaten fehlen links unten einige Pixel. Da LEDs ja selten kaputt gehen nützt vielleicht ein “Spezial-Reset” das ich nicht kenne. Wenn es kein bekannter Fehler ist, verschenke ich das Teil gerne (Porto müsste bezahlt werden AT €6, DE €13) → persönliche Nachricht bei Interesse.
Pixoo64 ist mein neuer Favorit.! :wink:
If you flash the Ulanzi back to the original firmware, do the issue still persists? If so, then you might want to contact Ulanzi/the seller, as the clock should not malfunction within such a short period.
Thank You @SunBeech! Actually I don’t know how to flasch back the device. I just followed instructions here to make it ready for Homey (Awtrix)
Anyway, I found an interesting device in Divoom’s Pixeoo 64, because of it’s much larger size and will use that instead of the defect device.
I am not sure whether you can use the flasher used for installing the AWTRIX firmware. Otherwise there is the original flash tool from Espressif for ESP32 devices. You can download the original firmware of the Ulanzi clock from the Ulanzi TC001 product page. But maybe @Bckp can help out on which tool is best to use.
Hi @Bckp, I understand based on discussions on AWTRIX’s Discord server, that the developer of AWTRIX 3 is about to release a new version: AWTRIX NG.
That seems to be a completely different version with new features using a different API.
Is that version something you plan to support/integrate in Homey as well?
Top secret info, i have new version of app that imlements AwtrixNG fully already prepared :slight_smile: just need to verify i did not broke old driver for awtrix 3 users, so on day of release of Awtrix NG i will release it too :slight_smile:
That is great news, and I won’t share your secret :wink:!
I assume that I would not be able to migrate my existing Awtrix 3-device in Homey and related flows to the Awtrix NG version?
sadly no :frowning: Awtrix NG despite the fact it uses same HW is completely rewritten, and its API is different too. I decided to start with fresh start rather then take elephant on my back during implementation… good news is, pairing work even if you have username and password set, and all options available to the API is available to the users as well :slight_smile:
Maybe also some nice things without the use of json?
Can jou please makes some out of the box flows?
Thx!
there will be basic ones, so there is no need to write JSON versions, but there is option… if you want some basic stuff like show message with icon, show app with icon, it is possible without json knowledge
