[APP][Pro and Cloud] Daikin ONECTA
Since the update to 7.7.0 I noticed the following with my Altherma 3 heat pump:
-The Homey flow to set the room temperature to 18 degrees at 22:00 is not functional most of the times, the temperature setting on the thermostat and temperature setting displayed in the native Daikin app both stay at 19 degrees (the value set for daytime). However, manually setting the temperature in Homey works fine.
-When setting the room temperature with the native Daikin app, the Daikin thermostat follows, but Homey does not update and keeps displaying the former room temperature setting. Repairing the device makes Homey display the right setting, but only once.
I never had these issues before. I also tried restarting the Homey Daikin app, removing and adding the Daikin heatpump and hot water tank, rebooting Homey, restarting the heatpump by powering off and on. No effect.
Did someone else notice this and solve it?
Nobody??? Here at home the suffering continues…..
Edit: looks like all problems are solved in version 7.7.2. :grinning_face:
Edit: unfortunately, the problem still persists. Homey updated twice, now running on v13.0.0. :frowning:
since yesterday this notice.
Performa airco
595f57eb-886c-4318-b511-4b16eea5d5c9
Check your WiFi / internet. This message means that the Daikin unit has no connection with the Daikin cloud….nothing to do with the homey app,..just reporting with the info provided by the Daikin cloud.
I have a question when you go in the device and then insight thou can see the energy consumption Of the device. Sadly this seems to be cumulative and not the consumption at that moment or day. Find this a bit sad. Is their a way around this? Because when looking at top Consumers then I do just see the day consumption?
Hi @Mickel_Luiten,
Our Daikin Altherma is in a fault state unfortunately, but the ‘good’ thing is your app sent notifications to the timeline so I get informed, nice!
There’s just one small problem with that, it keeps sending these messages over and over and my timeline is filled :smiley: :smiley: :smiley:
(And the list goes on :wink: )
As you may have seen, I have developed the Daikin Altherma with ESPAltherma app to connect to our Altherma over the local network using an ESPAltherma, I’ve added a guard to prevent spamming the timeline, see my GitHub repository.
I hope you can add such a guard against spamming, please feel free to reuse my code!
On the other hand, you now know every 30min the fault is still there…
Yes, but it fills the full timeline at every pass:
One message is bearable, but right now all other notifications that may be important get lost :confused:
Should be one every 30min but in your timeline there a a lot on the same time.
Will take a look at it. Thanks for reporting
I’m running into the following issue:
Through the app, I have added several air conditioners. Via the Matter Bridge, they become available in Apple HomeKit.
In Apple HomeKit they are displayed, but with the message “Not Supported”. I understand this may be caused by the app using custom capabilities instead of the standard Matter/HomeKit capabilities.
Could this be adjusted?
Is this something that could be resolved in a future update?
Can the leaving water temperature be controlled in cooling mode?
Currently it seems like when operating the Altherma 3 in cooling mode with fixed output, there is no option to control the leaving water temperature. In heating mode it is possible to control the offset as it is set to weather dependent.
Diagnostics report: 4a5af06e-1b11-4da1-912a-3a02bcdfa90a
Don’t know. If this can be controlled in the Daikin ONECTA app(android/iphone) is should be possible to also control it in homey, depends i think also on the controlmode and/or setpointmode.
Hello everyone,
None of the devices are working today, even after an attempted repair. The Daikin page opens (without prompting for credentials), you have to confirm it, but that’s it.
Daikin pushed firmware updates everywhere today and also updated the Android app. I suspect they made a change in the cloud?
No, Daikin cloud is unchanged, i have the issue after Homey update to 13.3.0-rc.15.
A other developers reports the same (fetch) error and already reported to Athom.
Rc16 is available that fixes the problem
Thanks Athom for Quik fix
Hey
Is it possible to control the FTXJ_AW9 device using the app? I want to be sure before I buy one of it
thanks for helping
Again, if the mentioned unit can be controled with the Daikin ONECTA (Android/iphone) app then it’s should also by possible in homey.
Ask your local installer which (smart) integration Daikin have on the mentioned unit
I have had this spamming my timeline last few weeks for no reason. Control works fine from what I can see
“Daikin unit Daikin vattenberedare is disconnected from the daikincloud and can only be controlled by remote”
There is a reason…your unit lost connection with the cloud so check your WiFi or internet connection
Problem is:
1. it’s connected via cable
2.Nothing else on the same switch lost connection
3. It happens multiple times over weeks
4. It spams the same message 10 times the same minute, then nothing. Then a few hours later the same thing.
5. I can see all temp changes in logs nothing is missing.
Hi all
Today I’m having two Daikin XTH 25 AC/Heater installed and was very happy to find this app for my Homey Cloud :heart_eyes:.
What are your best flows that you suggest I create with the nice equipments and app?
Im installing one in my upstairs bedroom to cover that whole floor and the one in my living room to cover that floor. It’s also the room were we have our furnace which I understand can work quite well with the XTH 25.
Thanks in advance.
Fredrik
