[APP][Pro and Cloud] Daikin ONECTA
I assume this will give some serious issues with the Homey Cloud, because they are talking about ‘applications’ and not ‘accounts’, which would make sense from a software pov. This means that the whole Homey Cloud is seen as one application.
Again, Homey Pro runs locally and therefor without issues, but the Homey Cloud is unable connect since this morning.
@Mickel_Luiten Can you confirm this is the case?
Rate-limiting is user-based.
This is a special rqeust from us to Daikin!
As for the Homey(cloud) it look like some part of the code is crashing the whole app.
This behaviour is not seen on Homey Pro’s.
Trying to fix it at this moment.
My app was crashing constantly on a homey pro earlier today or yesterday. Didn’t look into so much but noticed it
Running Homey Pro and it just crashed with the token/Id error again. Restarting app does work initially however all my airco devices are inaccessible since 21:00 CET
Did you repair all your Daikin devices?
That need to be done first to solve the autorization and token issue!!!
Please clarify how I can repair…
right click /repair
I tried that several times. It keeps telling me that I have an invalid ID or password. The password and ID I enter are correct but it keeps shutting me out even if I set a new password using “Forgotten Password” routine.
Just published version 4.2.2 that hopefully should fix the issue on Homey-Cloud.
I can not fully test it because to run a app in development mode on Homey Cloud it using a local docker container and therfor also the local public WANIP addres.
Thanks for clarifying that.
And thank for your effort in this matter, highly appreciated. Do you gave some sort of donation form?
That’s nice. I just installed it, but it keeps giving me an ‘Invalid response (403’ when trying to connect to the Daikin server.
See first post in this thread for donation link
The 403 could happen if your not authenticated to the new api platform.
It should be possible now to do a repair on all your devices. That should fix the 403 error without crashing the whole app
Tried several times, repairing, reinstall etc. Just sent you an e-mail with a screencast to your e-mail address.
Check, but a Paypal account is needed for that :wink: More than happy to donate, but I do not have Paypal.
Sorry no other ways to donate.
The 403 forbidden is probably a security measure on the Daikin platform because most homey cloud instances will do there request from the same public IP address.
If to many request are done the Daikin platform blocks this ip adress for some while.
In theory this should be normalized and the authorization should work again.
Please keep trying.
Sorry for all the inconveniences.
I still have issues with this, can’t add a single device! :frowning:
Only getting this below and 403 error …
UPDATE:
Issue fixed by repairing the devices as mentioned. Which is pretty weird as i could still control them perfectly fine in Homey. So if anybody else is having these issues in cards, repair the devices!
when trying to set the mode in a flow, i always get this error:
Anybody else experiencing the same? Existing cards/flows are still working, just can’t seem to change any existing one or add a new card to set the mode.
Thanks!
Hi all,
There is still a bug in the app that crashes the whole app mainly on homey cloud.
I working as fast if I can to fix it.
I received some logs from athom the identifying the issue.
Sorry for the inconveniences.
this message signed for me the rate limit. It solved itself after the timeout
