Haven’t had the change to test if this works now. Will keep you posted.
The Charge ID seems to work 50% of the time. It is now cleared when plugged out.
I’ve novices reboot in the past, but that’s not the case lately.
Maybe this app is an option ? It use modbus as connector. Alfen Eve Single / ACE EV Charger | Homey
I am working on an app that works via modbus only and also works on the double pro. Anyone interested to test it?
It does not support the “plug and charge” and “RFID” mode switching but all other functions 1F/3F switching, load balancing etc are working fine in my installation.
Anyone interrested in testing?
no more reboots. I actually take a combo of the two states. at night it is connected and doesn’t release it at all. during the day it logs in every 600s. reason is that then during the day I can still use the eve app. during the night, I never need to, so I go the other mode.
till now stable, and no disconnects.
hoping it can be included in the stable version, somewhere down the road.
Sounds great! Didn’t get round to testing just yet but I will do so. I’m guessing it’s not listed in the store and I’ll need to install it locally / manually instead?
I will publish it for testing shortly and publish a link tot the appstore here.
For now I’ve installed it using the repo of @Patrick_Van_Deursen ![]()
I have published for the app for testing
I tested your app but it doesn’t seem to solve my issue. I had Claude analyze the logs from this morning, which still show ~907 logins and then a reboot of the charger. Same behavior as the previous version I had.
Not sure: was I meant to first completely uninstall the previous version and then install this one via commandline? I did the latter, didn’t do an uninstall beforehand. It seemed to have upgraded in place.
Thanks for that! I’ve installed it. It came up with two devices, don’t know why cause I have a single line charger? The adding of the devices got stuck. After exiting the installation process it does show two devices, but both of them inresponsive. I noticed the prerequisites to have modbus enabled and active load balancing in energy management mode. My charger is partly controller by the back-office integration, I checked ACE but couldn’t find where to enable modbus. Could you help me out on which settings in ACE need to be changed?
That’s odd, mine seems to be lacking that setting. I have the option to change the profile from “Standaard” to “Comfortable + Groen” or “100% Groen”. The app itself is listed as “Development” running version 2.1.4.
Can you please have discussion about other apps in the support topics of those apps. This topic is for the Alfen app connecting through the API. Thanks!
I have opened a new topic for the modbus app, we can continue the discussion there
Alfen Pro NG9xx via Modbus - Apps - Homey Community Forum
I have tested the fork of @Patrick_Van_Deursen for a longer period of time now. This completely solves my connectivity issues, very happy with this. I’d highly recommend merging this in.
See below response I recently received from Alfen Support re. the issues I encountered:
In the Homey Pro app settings for the Alfen / Dongle integration, please adjust the polling/refresh interval from 30 seconds to 60 or 120 seconds.
Firmware improvements to handle frequent third-party session handshakes more gracefully are being developed for future releases, but extending the interval in Homey is the immediate, effective solution.
Good thing is that I understand that Alfen is working on improving the firmware - although no timelines are provided.
completely solved in the fork I posted. hopefully it will be interated.
I’ve charged the car a couple of times now since the “laadpas id” was introduced in the app. And succesrate of it showing up is about 30-40%. Any thoughs on why this is not stable?
