[APP][Pro] Ajax Security System
could you also do the following, go to Ajax app settings → Diagnostics → Refresh → copy diagnostics and send me this info in a dm. It should not contain any sensitivite information but it might be best to send it to me directly instead of a post here on the forum.
.331 test version doesn’t work
Version 1.0.331 crashed on startup.
As a result, the app no longer works.
apologies, should be fixed now, currently in America (9 hours difference) so took a little bit :stuck_out_tongue:
No problem, it’s working again. Thanks!
I’m running into a issue with my Ajax double switch. (LightSwitch 2-gang)
I successfully added the switch to Homey using the Ajax(Homey) app. Unfortunately, I can only control the right side of the switch in Homey. The left side either doesn’t appeal of cannot be controlled separately.
Please help!
Thanks in advance for your help! (I’m using a Hub 2 4G ) I’m using app version V1.0.345
Hi, could you try this build: https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/
Anyone out there that has an ajax doorbell and could confirm if it’s working now?
Hi, so is this issue resolved?
Thanks for a great app! Works perfectly. Would it be possible to add the emergency buttons / remotes? The small ones.
Thanks!
Much appreciated, try : https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/ (I added it to the panel tab)
While you’re at it.. I’m missing the fire/smoke alarm went off trigger. Or is there another way? I only see the on trigger. Same goes for sabotage and burglar alarm. No ‘when deactivated or off’.
Currently deep in creating redundancies but hopefully this build should help with that : https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/
Awesome! Sabotage and fire/smoke working already. Only burglar (inbraak) seems to be missing when deactivated. Good work. :slight_smile:
added that swell, same link
Thank you!
