[APP][Pro] Ajax Security System - Make Ajax alarms part of your smart home
So when will the Ajax smart plug and the relay be available in the app?
So thank you for your question. You can try: https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/
Thank you! :folded_hands:
Hi Mike,
Thanks for this app! I was trying to make my Sonos system say ‘Ding dong’ when the doorbell rings (because the Ajax homesiren chirp just sounds awful).
However the app can’t find any doorbell on my system. The account I’m logging in with has full admin access on the system and the doorbell.
Is this a known issue?
Hi there, unfortunately I don’t have a doorbell so i wouldn’t know. I assumed the doorbell was working after I fixed the cameras seeing as I got no more responses from people with the doorbell. If you would be so helpful to send me two diagnostic logs and maybe even do the extended one in settings of the app and send me a DM with it then I can help you out.
  1. reboot the homey or app and send a diagnostic right away after.
  2. click on add doorbell and send a diagnostic right away after
  3. go to settings of the app and copy the advanced diagnostic there. Paste it somewhere and send it to me.
Much appreciated
also could you try this version: https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/
@MikeTango
Very cool app, thank you for that.
Is it correct that the “LeaksProtect Jeweller” is not yet supported?
Can you support this one? I would otherwise be happy to help you with that.
it’s still in testing phase (aka need someone with the actual device to test it out). Gimme a hour and I’ll enable it in the test version and post It here.
I’m here and I’m happy to help you :wink:
awesome, almost done.
Should be enabled in this version: https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/
You have integrated shut-off valves, but not the flood detectors (Überschwemmungsmelder).
which version have you got installed? Cause in the version I just uploaded it shows me both devices
You’re right, sorry, missed it.
I was able to integrate it and will test it a bit. If I find something wrong, I will contact you.
Thank you for the quick integration :+1:t3:
awesome, it’s been some guessing so fingers crossed I did that correctly.
I tested the flood detector with water, everything works as it should. The alarm is triggered and then reset as soon as it is dry again.
I also have the battery-powered interior siren (Superior HomeSiren Jeweller), wired interior siren (Superior HomeSiren Fibra) and the Aussensirene (StreetSiren Jeweller) tested, these do not work as they should. When an alarm is triggered, nothing changes with the device in Homey. No log entry is generated either. It stays with the values of importing the devices into Homey.
Or do I get something wrong?
grafik
grafik
grafik
@MikeTango I now also have the PIR motion detector (Superior MotionProtect Plus Jeweller) tested, this one works and everything is written into the log.
grafik
But the PIR motion detector with photo (Superior MotionCam (PhOD) Jeweller) does not work, nothing changes in the homey device and no log entries are made.
grafik
Thank you for your feedback, much appreciated. Could you install this version and check again: https://homey.app/nl-nl/app/com.ajax.security/Ajax-Beveiligingssysteem/test/
Anything that doesn’t work, could you try out the function and then immediately after make a diagnostic report (can be the one via homey). This will help pin point the issue.
Again, much appreciated!
Hi Mike
I will test it next week and give you feedback :+1:t3:
Hi, Installed this nice app today, and connected it to my alarm.
Connection goes fine, but the app craches from time to time.
Anny idea what to do?
See: ec1399d6-4542-404b-8008-04ed137063b5
I use version v1.0.241
I updated to the test version but no result.
I also don’t get updates like motion detected and doorbell press.
Any tips?
