[APP][Pro] Airco Bridge – Mitsubishi Heavy Industries Smart M-Air / WF-RA
Airco Bridge connects Mitsubishi Heavy Industries air conditioners equipped with a Smart M-Air WF-RAC or WF-RAC-HTTPS Wi-Fi module to Homey Pro.
Please note that this app does not support all Mitsubishi or all air-conditioning systems. It is specifically intended for Mitsubishi Heavy Industries units that are
normally controlled through the Smart M-Air app.
Install Airco Bridge from the Homey App Store
How does it work?
The Homey app communicates with a separately installed service called AircoBridge. AircoBridge runs on a local computer, server, NAS or Raspberry Pi using Docker.
AircoBridge communicates directly with the WF-RAC module over your local network. Control and status information therefore stay on your LAN; the Mitsubishi cloud and a
manufacturer account are not required for normal operation.
The WF-RAC module must already be connected to your Wi-Fi network, usually by completing its initial setup with the Smart M-Air app.
AircoBridge installation and documentation
Features
  • Turn the air conditioner on and off
  • Set the target temperature
  • Auto, cooling, heating, dry and fan modes
  • Fan-speed control
  • Horizontal and vertical vane control
  • 3D Auto support
  • Indoor and outdoor temperature
  • Device status and error reporting
  • Current power consumption
  • Cumulative and monthly energy usage
  • Local communication between Homey, AircoBridge and the air conditioner
Requirements
  • Homey Pro
  • A Mitsubishi Heavy Industries air conditioner with a compatible Smart M-Air WF-RAC or WF-RAC-HTTPS module
  • AircoBridge running on your local network
  • Docker is recommended for installing AircoBridge
At present, AircoBridge has been tested with:
  • Indoor unit: SRK50ZS-WF
  • Wi-Fi module: WF-RAC-HTTPS
  • Wireless firmware: 025
  • MCU firmware: 200
Other WF-RAC models are expected to use the same protocol, but have not all been tested yet.
Feedback and compatibility reports
Feedback is very welcome, so we can list your model as supported or not supported.
If you test the app, please let me know:
  • Your indoor-unit model
  • Whether you use WF-RAC or WF-RAC-HTTPS
  • Your wireless and MCU firmware versions
  • Which functions work or do not work
  • Any errors you encounter during pairing or normal operation
Bugs and technical details can also be reported through:
Disclaimer
Airco Bridge and AircoBridge are community projects. They are not affiliated with or endorsed by Mitsubishi Heavy Industries.
Is there any reason for me not to use this app? Mitsubishi (WF-RAC) | Homey
This one works quite well.
Airco Bridge v1.1.0 is on its way to the Homey App Store!
This release adds per-air-conditioner presets. You’ll be able to select presets directly from the device controls and use the new Apply a preset action in Homey
Flows. Applying a preset restores its climate settings and turns the air conditioner on.
Preset support requires Homey OS 12.6.1 or newer and AircoBridge v1.1.0 or newer (Release v1.1.0 · CrazyHenk44/AircoBridge · GitHub). If you use an
older AircoBridge version, all existing climate controls will continue to work; only the new preset functionality will be unavailable.
If you want to use presets, update AircoBridge before updating the Homey app.
Links:
Feedback is very welcome—especially about preset controls and the new Flow action. When reporting a problem, please include your Homey OS version, AircoBridge
version, and the steps needed to reproduce it.
Airco Bridge v1.2.0 has been submitted for Homey certification. Once approved, this release will make adding and maintaining your AircoBridge connection much easier.
What’s new:
  • Homey will automatically discover AircoBridge instances on your local network.
  • The pairing screen will let you select the discovered bridge.
  • Existing devices can automatically follow changes to the bridge’s IP address.
  • Manual address entry remains available as a fallback.
  • The pairing screen and device-type naming have been improved.
Automatic discovery requires AircoBridge v1.2.0 or newer.
For the smoothest upgrade, update AircoBridge first and then install the Homey app update. Feedback about discovery, pairing, or IP-address recovery is very welcome.
Hi everyone,
Airco Bridge for Homey v1.3.0 has been submitted with a major expansion of its local automation integration.
This release adds:
  • Homey Flow controls to enable, disable and inspect AircoBridge automations
  • Manual-control status and a Flow action to resume automations
  • Automation-safe Flow actions for presets, power, temperature and operating mode
  • Triggers for executed and failed automation actions
  • Flow cards for self-cleaning and compressor start/stop events
  • Live operating current and compressor-frequency insights
You can find the new cards under your Airco Bridge device in the When, And and Then sections of Homey Flow. Existing devices do not need to be paired again.
Homey OS 12.6.1 or newer is required. The new automation features require AircoBridge v1.4.0; older bridge versions retain their existing climate controls.
Links:
Feedback on the new Flow cards and automation behaviour is very welcome.
