My guess is it works best with Advanced flow.
Advanced flows have the same problem for me, when I click brand or device type, no autocomplete appears.
A call to autocomplete is made, but an empty array is returned as JSON response:
Ill have another look at it asap!
I really like this app!
Would it be possible to add a predefined list with values:
- auto
- low
- medium
- high
- turbo
I have built an integration with my Samsung ACs, and would like to use this list to set the AC Fan Mode.
Thanks!
Hey Lucasz,
Welcome toe the forum!
I have just written a How-To-Request a predefined list:
Please send me a PM with the needed texts, and i will add them ![]()
Hi Arie,
Thanks, and thanks for your quick reply!
I can’t send PMs yet since I can’t find the option anywhere, so I hope this is ok:
"title": {
"en": "Auto, Low, Medium, High, Turbo"
"values": [
"id": "auto",
"title": {
"en": "Auto",
"nl": "Auto",
"de": "Auto"
"id": "low",
"title": {
"en": "Low",
"nl": "Laag",
"de": "Niedrig"
"id": "medium",
"title": {
"en": "Medium",
"nl": "Medium",
"de": "Mittel"
"id": "high",
"title": {
"en": "High",
"nl": "Hoog",
"de": "Hoch"
"id": "turbo",
"title": {
"en": "Turbo",
"nl": "Turbo",
"de": "Turbo"
Yeah, thats fine.
I have added the list and it’s in review/test:
Thanks for taking the effort to make Homey better <3
What about we just make it possible to select any custom string-type capability to show on the device’s tile? Seems like the most elegant solution to me!
You’re welcome!
And thanks for letting me (try)! ![]()
Well yeah, that would be very nice, neat, more consistant and probebly less -if-then-else-else-else statements for you to program ![]()
So, i am aboluty down with that idea!
This has finally been resolved in version 2.9.20.
Hello all,
I hope that I’m in the good forum for my question. Actually I try for the first time to use this wonderful app. The first thing that I want to try is to import a TEF (The demo one actually: The Flow Exchange(r) - Exchange Your Flows with Others! - #3 by Arie_J_Godschalk).
I’m opening the app settings, click on import, paste the TEF in the text area, click on “Read Flows” and … nothing…
I tried with other TEF without success.
Could somebody explain to me what could be the problem please ?
Best,
Jerome
Hey Jerome, im looking into it, but quick question? Which version of DC are you on?
Because the last few days, there was a bug in it making TEFs not work.
That was solved in this mornings published version.
EDIT
NVM, it’s a bug in DC, ill solve it asap.
Sorry about that, but for HP2023 i have made many changes to DC and by mistake, to solve another bug, i release an HP2023 build into live.
Now, i thought i had solved all issues, but that seems to be not the case.
I’ll let you know when i have it working again.
EDIT
This only effects TEF export/import, templates etc.
Not AVDs themself or the rest of the apps functionalities.
I am really looking forward to using my “old” Homey for development and building some good release-streets, to avoid this kind of bug’s creeping into production version.
And, i wasn’t aware (a while ago) that WebApi would also change to version 3 and boy, it has some important differences between old en new Homey (being worked on however).
I use the very latest DC version with Homey pro 2019 so indeed… I’m affected by the issue ![]()
Best,
Jerome
Amazing app, kudos!!
This comment helped me to finally change the status indicator to any of the tagged variables. Unless I missed it, allow me to suggest you add this (or an additional reference) to your initial explanation?
What do you mean by this? Which one?
In the app during AVD creation?
In the App settings?
The first Post of this Topic?
Solved.
Altho the athom-api is deprecated, and we are supose to use the homey-api, i just switched back to athom-api.
Homey-api keept giving errors an, it’s slow, eats memory and it doesn’t react to events.
Thuse, i didn’t work (correct).
Now i have switched back, all issues are gonne (i havent removed all work for the HP2023, no worries).
Update to 2.9.22 and enjoy AVD, TFE and there TEF’s!
Works ! thanks a lot for your reactivity !
What should I understand from the fact that athom-api is deprecated ? Does it mean Homey pro 2019 = athom-api and Homey pro 2023 = homey-api and that things will start not to work anymore for HP2019 ?
Best,
Jerome
I’m sorry, but you’re seeing ghosts.
Any app should not hold async onInit, and because I’ve added a helpful message (instead of a cryptic ‘CreateClientTimeout’) you think I am targeting your apps?
I have no idea what your apps do, or what they need, but any app should simply resolve onInit a.s.a.p. and in the Web API calls should await whatever you need. That’s just good programming.
