[APP][Pro] Adax with Power Estimation
Hi everyone,
The App Store description is a short summary. Full setup instructions, technical explanations and limitations are maintained here; use the app’s Support or Community link to return to this guide.
The app uses Norwegian when Homey is set to Norwegian, and English for every other Homey language. This includes settings, Flow cards and device settings. The App Store description and this Community topic remain in English. Raw JSON logs, API field names and upstream error details remain technical.
I made Adax with Power Estimation because I wanted estimated watts and more useful energy information from my Adax heaters in Homey. This topic is for setup instructions, questions, feedback and release notes.
App Store · Test version
Adax with Power Estimation connects Adax WiFi panel heaters and thermostats to Homey through the Adax Cloud API. Control temperature and on/off, use your heaters in Flows, and follow estimated power and energy consumption. This is an unofficial community app with no affiliation to Adax.
Getting started
  1. If you use the official Adax Homey app, remove the devices from that integration first. You can continue using the Adax mobile app.
  2. In the Adax mobile app, open Account → Third-party integration / External API and create an API password. Note your account ID and the generated password.
  3. Open this app’s settings in Homey, enter your Adax account ID and API password, and save.
  4. Add a new device in Homey, select this app, and choose the Adax rooms to import.
  5. Set the correct nominal power in each device’s advanced settings. The default is 1000 W. For a room with multiple heaters, enter their combined wattage.
Rooms and heaters
The Adax API is room-based. Each device added to Homey represents an Adax room, which may contain several physical heaters. Heaters in the same room share control, status and energy information. Place heaters in separate Adax rooms if you want to control them independently.
Power and energy
Power in watts is estimated using the configured nominal wattage, available Adax status, temperature and local logic. It is not a physical measurement of the heating element.
Internal Adax power estimates use the unadjusted internal temperature; the temperature adjustment only changes its display in Homey. External Flow estimates retain the adjusted external temperature. Internal input expires 15 minutes after receipt; external input uses its configured maximum age. If neither valid temperature nor explicit heating status is available, watts become unknown rather than retaining an old estimate indefinitely. Local energy accumulation leaves a gap awaiting cloud coverage; unknown is not confirmed zero consumption. The displayed temperature can remain the last received value; its receipt age is shown in diagnostics. Receipt time does not establish the age of the upstream sensor measurement.
Energy consumption combines local accumulation with available cloud energy data. Accepted cloud data replaces estimates for the corresponding periods. Local estimates continue between cloud updates and when cloud energy is unavailable. Requests are shared between devices on the same Adax account to reduce API traffic.
Each device also has an additional consumption display, separate from the total energy counter. It shows consumption today by default. In the device settings, you can choose last hour, last 24 hours, today, yesterday, this month, last month, this year, or total logged by the app. The selected period appears alongside the value.
Flow conditions let you check whether consumption for a selected period is above or below a threshold, so you can use it in notifications and automations.
External temperature sensor
You can select External via Flow in a device’s settings and supply readings through the Set external temperature Flow action. If readings become older than the configured maximum age, the app falls back to Adax’s internal temperature.
External readings are used for temperature display and local estimation in Homey. They do not replace the temperature used by the heater’s own thermostat.
Limitations
  • Adax cloud updates can be delayed. Changes made on the heater or in the Adax mobile app may take time to appear in Homey.
  • A heater being enabled does not confirm that its heating element is currently drawing power. Estimated watts can differ from actual consumption.
  • Cloud energy may be delayed or unavailable for some rooms. The app cannot provide a guaranteed real-time status or billing-grade energy measurement.
  • Set the nominal wattage correctly. An incorrect value affects local power and energy estimates.
  • For strict load limits or peak protection, use a physical power meter and allow for delayed or uncertain heater status.
  • Compatibility depends on Adax’s API and cloud services and may change if Adax changes them.
The app works alongside the Adax mobile app, but must not be used alongside the official Adax Homey app. It is provided as-is, without warranty.
Optional diagnostic sharing
If you would like to help improve the estimates, you can enable voluntary diagnostic sharing in the app settings. Use v0.3.59 or newer, tick the consent box and press Save choice. Sharing is off by default and is not required to use the app.
New observations of temperature, setpoint, enabled state, estimated/nominal watts, cloud energy timestamps and energy_log results are uploaded about every 15 minutes, using existing Adax requests. Only rooms added to that Homey are shared. There are no extra Adax calls for this feature. From v0.3.65, observations can also include the reason and time of a power estimate, the effective temperature, internal/external source, offset, setpoint, hysteresis and retained-estimate timing. This explains the local estimate and does not confirm physical heating. From v0.3.66, internal-temperature decisions can also include a passive candidate estimate without the display offset. The candidate does not change live watts, heater control or energy totals; external-temperature behavior is unchanged. Long-retained estimates are explicitly marked uncertain after 30 minutes.
From v0.3.73, optional app-health reports can include Homey CPU/memory warnings and startup events, with app version, bounded warning counts and timestamps. Read the updated disclosure and save your sharing choice again to include these new events; existing energy consent does not enable them automatically. A small retry queue keeps up to eight pending events for at most two days across restarts. Warnings can upload immediately at most once per minute. A restart after a warning does not establish a crash cause. No continuous CPU probe, raw process logs or stack traces are shared.
From v0.3.86, voluntary participation includes logging of errors and possible crashes. Read the updated disclosure and explicitly save your sharing choice again to include unhandled runtime-failure categories and previous sessions whose exit was not observed. Error messages, file paths and stacks are excluded. A missing exit can also follow a normal restart, update or power loss; the cause remains unknown. Reporting is best effort and abrupt termination can leave no final report. The same bounded outbox and withdrawal rules apply.
Names, original Adax IDs, account credentials and Homey access are not shared. Installation, room and heater identifiers are pseudonymous, not guaranteed anonymous: usage patterns can still reveal how a home is used. I have access to the data, which is retained for up to 30 days. Switching sharing off stops uploads and requests deletion; if the server is unavailable, deletion is retried. Privacy details.
Reporting a problem
Please include the app version, Homey model/firmware, what you expected, and what actually happened. Mention whether you changed the heater through Homey, the Adax app or the heater itself. For energy problems, include the affected period and whether energy_log is succeeding or returning an error in the device diagnostics.
Some Adax rooms currently return HTTP 502 for energy_log while other rooms work. Local estimates and available withEnergy data continue, but this does not prove the estimate is physically accurate. The app cannot make Adax cloud updates arrive faster.
Please do not post API passwords, account IDs, access tokens or complete unreviewed diagnostic dumps. Screenshots may also contain private names and usage information, so check them before posting.
I will keep the setup information in this first post and add release notes as replies below.
From v0.3.72, the app also adds an uncalibrated passive average-power hypothesis (linear_band_v1): full nominal power below the hysteresis band, zero above it and a linear fraction within it. It does not control the heater or live watt values. A bounded local history records live and candidate energy before cloud corrections. Optional sharing can include up to five comparisons for the same cloud periods, with coverage and unknown totals when incomplete; only periods entirely after consent are shared. Cloud energy and the candidate are not independent physical measurements.
From v0.3.87, app settings show consumption-source quality by room and period: local, provisional cloud, energy-log cloud, mixed, incomplete or limited source history. This reads recent saved accounting periods on demand; older totals can remain available without detailed source provenance. The newest minute may await its normal checkpoint, and allocation inside a cloud period may be estimated. It does not change energy accounting or certify physical accuracy.
Control Health separates control, sync and runtime error events within its retained snapshot (up to 250 events from the last 24 hours). Older errors may be absent. The manual support-report button prepares a report for review/copying with version, hardware family, an optional selected model, room count and fixed error/source states. It excludes names, IDs, credentials, temperatures, consumption values and raw errors. It is not uploaded automatically; sharing consent is unchanged.
From v0.3.88, five cloud-energy metadata fields are saved only when their values change. Every response still undergoes processing, reconciliation, comparisons and diagnostics; simulated consumption, controls, Flow, polling and voluntary reporting are retained. Failed writes are retried. This reduces repeated storage work without a claimed CPU-reduction percentage.
Version history
Changes, newest first. See post 1 for setup and limitations.
Later releases supersede historical behavior, including pre-v0.3.44 energy-meter policy.
v0.3.88
Build255 live. Skip five unchanged withEnergy metadata writes; retry rejected writes.167 tests. Reconciliation, simulation, controls, polling and reporting retained. No measured CPU saving claimed.
v0.3.87
Build254 superseded by88; review retracted. Consumption-source quality, separate error counts, manual private support report and recovery tests.163 tests.
v0.3.86
Build253 superseded by87. Optional error reporting with renewed consent, bounded outbox and unknown exit cause; compact history retained.
v0.3.85
Build 252 draft only, superseded by 86. Prepare optional runtime-failure reporting.
v0.3.84
Build 251 test. Automatic lossless compact history, serialized migrations. Same-code two-Homey pilot: mean app CPU 15.39% to 10.54%; short windows, not a guarantee.
v0.3.83
Build 250 compatibility pilot: reversible compact history, legacy default. Certification retracted.
v0.3.82
Build249 test. Retains81 fixes; append warnings without reformatting prior rows. No control/accounting/polling changes.
v0.3.81
Build248 draft, superseded by82. Batch comparisons, reduce copies, binary lookups, cache fixes, spread energy ticks.77/78/80 local pilots.
v0.3.79
Build247 draft only. Period lookup and diagnostic-read CPU fixes, included in81.
v0.3.76
Build246 test. Cache invalidation, skip duplicate unchanged-power checkpoints and legacy mirrors. Transitions/expiry/minute accounting retained.140 tests;74/75 local pilots.
Earlier updates: v0.3.73–v0.1.0
v0.3.73
Build245 test. Reduce repeated calendar/history/JSON work. Optional resource-warning/startup sharing requires renewed consent; restart cause unknown.
v0.3.72
Build 244 live. Unadjusted internal temperature for watts; stale input becomes unknown/local energy gaps. Passive band and pre-correction coverage comparisons. External Flow, commands and polling unchanged.
v0.3.71
Build 243 uploaded; channel unverified. Use flat drawn heater artwork on white, with heat waves scaled to the panel perspective. Remove realistic shading and depth.
v0.3.70
Refine the heater driver image with dimensional details inspired by the icon, on a clean white background.
v0.3.69
Use an icon-matched black heater line drawing on a plain white background for both driver image sizes.
v0.3.68
Shorten the English store summary; preserve the full Community guide. Use an existing Adax product photo on white.
v0.3.67
Localize app settings, diagnostics, pairing and Flow errors in Norwegian/English using Homey’s language. Keep store and Community text English. No control or energy changes.
v0.3.66
Build 238 update, 20 October. Passively compare internal temperature without display offset. Flag retained estimates, model differences and coverage; clarify offset use.
v0.3.65
Add optional estimate basis/time, temperature/source/offset, setpoint/hysteresis and retained age. Keep decision and cloud observation times separate.
v0.3.64
Direct support requests to the app’s Homey Community forum topic from the App Store support link and English description.
v0.3.63
Restore the full English App Store instructions, technical explanations and limitations. Keep the Homey Community link for discussion and release history.
v0.3.62
Documentation release with the linked Homey Community guide, support discussion and complete version history. Community access uses the App Store metadata link; app behavior is unchanged.
v0.3.61
Add the Homey Community topic with setup instructions, limitations and release notes. Shorten the English App Store description; app behavior is unchanged.
v0.3.60
Rewrite the English app description with setup instructions, feature information and limitations. Remove outdated version history and internal implementation notes.
v0.3.59
Limit voluntary withEnergy/energy_log diagnostic uploads to rooms added on this Homey. Exclude other Adax rooms; consent and heater behavior unchanged.
v0.3.58
Fix consent checkbox with standard Homey web layout. Explicit consent/Save retained; off by default.
v0.3.57
Add optional sharing with explicit consent, off by default. Batch pseudonymous temperature, power-estimate and cloud-energy observations. Withdrawal clears uploads and requests server deletion. Controls, energy calculations and polling unchanged.
v0.3.56
Collect bounded timing observations from existing withEnergy replies, with receipt times and heater values. Export in settings; batched checkpoints survive restart. No extra API calls or accounting/control changes.
v0.3.55
Preserve power transitions: merge only local periods with matching energy/baseline rates so partial cloud replacement cannot spread energy to other intervals. Existing history unchanged; gap filling shadow-only. Controls/correction policy unchanged.
v0.3.54
Add bounded withEnergy gap shadow diagnostics for overlapping hour averages. Energy totals, watts, controls, reconciliation and API traffic unchanged.
v0.3.53
Show estimate uncertainty and retained age during this app session. Zero estimated watts does not prove no heating. Simulation, reconciliation and control unchanged.
v0.3.52
Preserve desired state during rapid commands; reject stale sync/confirmations. Separate estimates from delayed energy HTTP. Harden HTTP/token renewal, count attempts and fix timezone boundaries. Add restart-safe period reconciliation and conservative historical repairs. Old Insights unchanged; enabled is not proof of heating.
v0.3.51
Resolve historical energy_log room names from cache; no extra requests or timestamp changes.
v0.3.50
Show home and room names for energy_log attempts, successes and last failures. Explain withEnergy account-wide request scope with room names, without extra API calls.
v0.3.49
Fetch energy_log every six hours per room, back off repeated failures to 12 and 24 hours, and serialize requests with ten-second spacing. Local estimates and withEnergy remain enabled.
v0.3.48
Validate energy fields without treating missing values as zero. Accept revisions to the same provisional hour without double counting. Show withEnergy reconciliation status and applied period time, with explicit timing uncertainty.
v0.3.47
Distinguish energy_log attempts from successful responses, identify the corresponding rooms, and preserve success timestamps during failures.
v0.3.46
Prevent overlapping cloud energy from being counted repeatedly. Reconcile explicit periods, handle room-specific energy log failures, reject implausible cloud readings, and show current per-room energy log status and dates. Historical meter values are preserved.
v0.3.45
Device view improvement: show the current effective room temperature alongside power, energy, and consumption without adding API requests or duplicate Insights history.
v0.3.44
Energy baseline hardening: prevent historical Adax energy from appearing as new consumption after long idle periods, preserve existing meters during migration, and keep Homey cumulative energy monotonic while cloud corrections settle.
v0.3.43
Device lifecycle hardening: prevent stale timers from crashing the app after a Homey device is removed, and show a clear unavailable message when a heater room no longer exists in the Adax account.
v0.3.42
Settings diagnostics improvement: add a lightweight Control Health summary with recent command count, failures, queue status, pending-control events, last restart, and uptime without loading the full runtime JSON log.
v0.3.41
Stability hardening: settings diagnostics are now read-only on open, diagnostic histories expose sample counts with stricter caps, pending heater controls are reported after app restarts, and target temperature changes preserve an off heater instead of sending on-fallback payloads.
v0.3.40
Diagnostics retention improvement: keep 30 days of shared cloud diagnostics by compacting raw samples into hourly buckets instead of deleting history, preserving trends while staying light on Homey Pro 2019 memory.
v0.3.39
Stability fix for Homey Pro 2019: compact shared diagnostic histories and cap future diagnostic samples to reduce memory pressure that could interrupt queued heater control commands.
v0.3.38
Control UI fix: optimistic on/off changes now immediately update estimated power as well, so heaters turned off no longer keep showing local power while cloud confirmation is pending. Off commands also include a fallback payload for stricter Adax rooms.
v0.3.37
Settings page hotfix: opening the settings dialog now loads the normal diagnostics and rolling API usage graph automatically while keeping the heavy runtime JSON log behind the manual Refresh runtime log action.
v0.3.36
Settings page responsiveness: the app settings dialog now becomes ready immediately, loads account diagnostics progressively, and no longer fetches/renderes the runtime JSON log during initial open.
v0.3.35
Control stability: Adax control commands are now queued per shared account with a short debounce and spacing between requests, while Homey still reflects user changes immediately and keeps pending state until the cloud catches up.
v0.3.34
Fold remaining pre-hybrid estimates into the cloud baseline without changing total energy. Clear old correction history and clarify diagnostics.
v0.3.33
Use withEnergy provisionally between energy_log updates without double counting. Update reconciliation diagnostics only when new cloud energy is applied.
v0.3.32
Preserve total energy while clearing stale reconciliation backlog and deviation history predating the energy_log timestamp fix.
v0.3.31
Fix energy_log millisecond timestamps. Show reconciliation in kWh and replace misleading tiny-delta percentages with kWh differences and context.
v0.3.30
Use a 48-hour API usage baseline with a retention buffer so baseline collection can complete.
v0.3.29
Remove the unsupported process-memory probe; retain uptime, restart and account diagnostics.
v0.3.28
Guard Homey process-memory errors to prevent runtime diagnostics from crashing the app.
v0.3.27
Record uptime, the previous event on startup, and a 15-minute diagnostic heartbeat to investigate unexpected restarts.
v0.3.26
Remove obsolete sync tracing and noisy room logs; retain control-first startup and guarded energy synchronization.
v0.3.25
Show runtime events in Oslo time alongside precise UTC/epoch timestamps. Replace heater artwork.
v0.3.24
Restore energy_log behind startup and post-control quiet periods to keep cloud-energy requests away from heater changes.
v0.3.23
Register controls before first sync. Delay withEnergy after startup and recent commands to avoid blocking controls.
v0.3.22
Restore withEnergy with batched diagnostics; keep energy_log temporarily disabled. Schedule adaptive polling one minute before observed refreshes.
v0.3.21
Restore local energy and consumption display while keeping cloud reconciliation temporarily disabled for crash isolation.
v0.3.20
Temporarily disable background energy processing, consumption refresh and the energy ticker to isolate crashes; retain temperature/status sync.
v0.3.19
Defer all control work to the next tick so capability listeners acknowledge Homey immediately without logging or storage work.
v0.3.18
Add post-control polling quiet periods, serialize overlapping device tasks, improve log copying and poll slightly after observed refresh intervals.
v0.3.17
Prevent diagnostic settings updates from recursively triggering sync. Skip unchanged writes and trace sync after controls.
v0.3.16
Simplify UI-first background control and add persistent JSON runtime logs for crash investigation.
v0.3.15
Return immediately from heater listeners without pending-state writes or immediate sync; send commands in the background.
v0.3.14
Restore the earlier optimistic control path, including pending state, adaptive polling boost, cache invalidation and scheduled sync.
v0.3.13
Remove aggressive immediate and delayed forced post-control sync; rely on normal polling to reduce crashes.
v0.3.12
Store lightweight pending state instead of immediately rewriting capabilities/power. Sanitize unavailable errors.
v0.3.11
Stop writing capabilities inside their own listeners to address timeouts and crashes. Improve control errors.
v0.3.10
Use English subtitles in both locales; rename supported devices to Adax WiFi Heaters.
v0.3.9
Rename to Adax with Power Estimation; retain English readme and Norwegian translation.
v0.3.8
Rename to Adax WiFi Unofficial; use an English main readme with Norwegian translation.
v0.3.7
Apply on/off and target changes optimistically while cloud commands run in the background, avoiding the timeout toast.
v0.3.6
Clarify that Homey imports Adax rooms and independent control normally requires one room per heater.
v0.3.5
Explain separate Adax rooms for independently controlled heaters because the API is room-based.
v0.3.4
Show how many rooms return energy_log HTTP 502; keep hourly backoff limited to failing rooms.
v0.3.3
Show that rooms returning energy_log HTTP 502 use 60-minute polling despite shorter account targets.
v0.3.2
Explain temporary hourly energy_log polling for rooms returning HTTP 502.
v0.3.1
Back energy_log polling off to hourly for rooms returning HTTP 502 until requests succeed.
v0.3.0
Stop returning saved API passwords to settings. Compress large API usage histories for browser responsiveness.
v0.2.99
Remove separate current/peak boxes from the API usage chart for a cleaner layout.
v0.2.98
Use a compact API chart with a 0–8000 scale, threshold zones and every rolling-count change.
v0.2.97
Retain enough request history for a rolling 24-hour graph with current/peak usage and 48-hour warm-up guidance.
v0.2.96
Apply the adaptive energy_log interval to cache age. Distinguish API fetch timing from dataset refresh timing.
v0.2.95
Remove development instructions from store text, clarify mobile-app compatibility and track every successful energy_log fetch.
v0.2.94
Track withEnergy refreshes by energyTime snapshots, adapt polling and retain a lightweight cloud-energy event log.
v0.2.93
Track energy_log refresh timing from successful fetches rather than rising values; adapt polling accordingly.
v0.2.92
Replace store artwork with estimated-power promotional images.
v0.2.91
Replace heater artwork with glowing panel-heater images.
v0.2.90
Replace store artwork with live-power promotional images.
v0.2.89
Generate crisp heater PNG artwork from the new square source image.
v0.2.88
Restore original sharp store artwork after the failed swap.
v0.2.87
Swap small and large app artwork while retaining required image sizes.
v0.2.86
Replace heater images with user-supplied panel-heater artwork.
v0.2.85
Restore the previously working custom heater SVG.
v0.2.84
Restore a simple heater SVG for clear browser/mobile tiles.
v0.2.83
Use a fixed dark fill to prevent washed-out or hidden heater artwork.
v0.2.82
Convert cropped heater artwork to transparent SVG, removing the outer background.
v0.2.81
Convert supplied heater/chart artwork to transparent SVG without a background layer.
v0.2.80
Convert the consumption chart PNG to a transparent SVG summary icon.
v0.2.79
Add padding around cropped heater artwork for smaller, cleaner browser tiles.
v0.2.78
Test a true SVG reconstruction of cropped heater artwork.
v0.2.77
Test unchanged heater PNG artwork embedded inside SVG.
v0.2.76
Refresh the heater icon from newly cropped artwork.
v0.2.75
Convert supplied heater artwork to an SVG preserving its silhouette.
v0.2.74
Shorten consumption labels and display values with two decimals.
v0.2.73
Persist the consumption-summary reset migration flag so future updates do not reset it again.
v0.2.72
Start the extra consumption display from zero on upgrade instead of seeding from total energy.
v0.2.71
Convert the consumption chart PNG to a monochrome SVG mask preserving its silhouette.
v0.2.70
Replace the raster-wrapper experiment with a monochrome SVG chart icon.
v0.2.69
Use SVG for more reliable consumption-icon rendering.
v0.2.68
Use the supplied chart PNG unchanged for the consumption icon.
v0.2.67
Simplify the consumption icon with thinner strokes and more spacing.
v0.2.66
Make the consumption icon slimmer and more readable in compact tiles.
v0.2.65
Use a bolder chart-and-arrow consumption icon.
v0.2.64
Fix initialization that left consumption at 0.000 despite known total energy; refine the chart icon.
v0.2.63
Seed existing consumption displays from visible total energy when needed; refine the report icon.
v0.2.62
Add a custom summary icon for the extra consumption display.
v0.2.61
Default extra consumption to today, include the selected period and bootstrap existing devices from history.
v0.2.60
Add selectable consumption periods, period-based Flow conditions and Compose capability/condition definitions.
v0.2.59
Remember previously seen energy_log periods across responses to prevent recounting.
v0.2.58
Seed older newly discovered energy_log periods as history rather than fresh consumption.
v0.2.57
Keep withEnergy as fallback when energy_log is healthy to prevent double counting.
v0.2.56
Restore both energy_log attempt and change timestamps in shared diagnostics.
v0.2.55
Replace the energy_log attempt timestamp with its last-change timestamp.
v0.2.54
Clarify the rolling 24-hour Adax request limit beside the counter.
v0.2.53
Adapt withEnergy and healthy energy_log polling to observed data-change intervals; expose cadence diagnostics.
v0.2.52
Show average energy_log change intervals and poll healthy endpoints more frequently.
v0.2.51
Add repository hygiene/development scripts, remove unused pairing UI and document Compose development.
v0.2.50
Separate temperature-source/energy modules and unify diagnostic timestamps without intended behavior changes.
v0.2.49
Migrate app metadata, driver manifest and Flow cards to Homey Compose without runtime changes.
v0.2.48
Move the Adax room ID higher in advanced settings.
v0.2.47
Store Flow-fed temperatures without changing display until External via Flow is selected.
v0.2.46
Add an external-temperature Then card directly in the manifest.
v0.2.45
Guard missing language/Flow wiring during external-temperature startup to keep the app available.
v0.2.44
Document external temperature via Flow, maximum age and fallback.
v0.2.43
Add per-heater external temperature via Flow with configurable maximum age and internal-temperature fallback.
v0.2.42
Make the Norwegian store description more technical and community-focused.
v0.2.41
Simplify Norwegian store text and align setup wording with the app.
v0.2.40
Fix remaining Norwegian characters in setting labels and hints.
v0.2.39
Add per-heater calibration for the room temperature shown in Homey.
v0.2.38
Use Adax WiFi Unofficial consistently in store text.
v0.2.36
Rename to Adax WiFi Unofficial with Estimated Power.
v0.2.35
Show 30-day average local/cloud deviation alongside cloud energy and last correction.
v0.2.34
Display accumulated cloud energy in kWh.
v0.2.33
Show accumulated cloud energy and the last reconciliation adjustment.
v0.2.32
Update room cloud-energy timestamps only when Adax returns a new value.
v0.2.31
Remove redundant energy timestamp settings and fix Norwegian encoding.
v0.2.30
Remove less useful debug fields and clarify remaining energy labels.
v0.2.29
Add adaptive post-command polling and clarify shared accounts, migration and app-maintained room information.
v0.2.28
Restore diagnostic refresh and protect room IDs while allowing manual watt changes.
v0.2.27
Migrate existing room IDs to text so watt changes pass validation.
v0.2.26
Show average withEnergy change intervals.
v0.2.25
Show when withEnergy last changed.
v0.2.24
Remove the lingering five-minute withEnergy cache so one-minute polling takes effect.
v0.2.23
Run withEnergy correction every minute with shared account polling.
v0.2.22
Keep only 30-day average and last command-confirmation timing.
v0.2.20
Show average and last Homey-to-cloud command confirmation time.
v0.2.19
v0.2.18
Track average and last command-confirmation time in shared settings.
v0.2.17
Rename fetch labels to attempt so failures are included clearly.
v0.2.16
Record last fetch attempts even when content or energy requests fail.
v0.2.15
Move the 24-hour request counter to the top of diagnostics.
v0.2.14
Show request results as Success or the actual error, replacing error-only fields.
v0.2.12
Preserve renamed devices, place cloud info below editable settings and fix Norwegian encoding.
v0.2.11
Poll withEnergy every five minutes and energy_log hourly; show 24-hour request totals.
v0.2.10
Present cloud values as information; document manual nominal power with a 1000 W default.
v0.2.8
Remove legacy device credential fields and separate room diagnostics from shared account diagnostics.
v0.2.7
Skip the fragile credentials pairing view and select devices using saved credentials.
v0.2.6
Simplify pairing credentials with Homey’s native global API.
v0.2.5
Fix cross-origin Homey access during credential pairing.
v0.2.4
Validate credentials in settings and make Refresh diagnostics fetch fresh Adax data.
v0.2.3
Fix pairing credentials view loading to reuse saved credentials.
v0.2.2
Fix settings loading with callback-based Homey APIs and onHomeyReady.
v0.2.1
Share cached account polling; separate shared cloud and room-specific diagnostics.
v0.2.0
Reset versioning to 0.2.x after the shared credentials and setup changes.
v0.1.66
Follow-up build: continue normal versioning after the shared App Settings credentials update.
v2.0.0
Major update: shared Adax credentials are now stored once in App Settings, pairing reuses them automatically, devices prefer central credentials with legacy fallback, and the app description/readme now matches the new setup flow.
v0.1.65
Shared app credentials via App Settings; pairing now reuses saved Adax Account ID/API password and devices prefer central credentials with legacy fallback.
v0.1.64
Energy reconciliation update: when Adax withEnergy returns a positive cloud delta, the app now clears local energy overlay so Homey follows cloud-backed energy more closely instead of preserving local drift.
v0.1.63
Energy model update: local energy now remains the continuous base, content?withEnergy is the primary cloud reconciliation every 15 minutes, and energy_log is reduced to a once-daily background history check.
v0.1.62
Rate-limit UX update: default polling is now 60 seconds, new devices start at 60 seconds, and HTTP 402/429 now show a clearer Adax request-limit message during pairing and on affected devices.
v0.1.61
Safety guard: set the minimum regular polling interval to 30 seconds to match observed Adax API limits and reduce accidental request-limit lockouts.
v0.1.60
Rate-limit compatibility update: treat documented Adax request-limit responses (HTTP 402) the same as HTTP 429, with automatic backoff to reduce repeated API lockouts.
v0.1.59
Rate-limit reduction: raised the default status polling interval to 30 seconds, reduced post-control sync retries, and kept the staggered 15-minute energy polling strategy to further reduce Adax API pressure.
v0.1.58
Polling resilience update: regular status sync no longer requests withEnergy on every poll, HTTP 429 now triggers automatic backoff instead of quickly making the device unavailable, and cloud energy diagnostics remain split between energy_log and withEnergy.
v0.1.57
Energy polling update: staggered Adax energy_log and withEnergy polling to every 15 minutes each (offset by 7.5 minutes), split diagnostics into separate energy_log/withEnergy error fields, and treat HTTP 429 as transient to avoid unnecessary device dropouts.
v0.1.56
Energy fallback update: when Adax energy_log fails, the app now uses content?withEnergy=1 as a conservative fallback and only applies positive hourly deltas as cloud-backed energy corrections.
v0.1.55
Diagnostics polish: energy diagnostic timestamps now render in Europe/Oslo time so Adax sync/attempt times match Norwegian local time.
v0.1.54
Energy diagnostics update: added last Adax energy attempt and last Adax energy error so failed cloud energy syncs are visible directly in device settings.
v0.1.53
Energy diagnostics update: added Adax energy point count, latest Adax point timestamp, and latest Adax point value to help distinguish missing cloud data from local-only energy accumulation.
v0.1.52
Energy diagnostics: added device settings that show the last Adax energy sync time, the latest Adax energy delta, and the current local energy overlay.
v0.1.51
Energy fix: added a dedicated local energy ticker so meter_power keeps increasing from live watt usage while Adax cloud history still reconciles in the background.
v0.1.50
Seed energy meter from latest Adax energy point on first sync.
v0.1.49
Refine thermostat icon waves to be smaller and higher.
v0.1.48
Refresh thermostat driver images using new square source photo.
v0.1.47
Update short description and replace driver images again.
v0.1.46
Update Norwegian description and thermostat driver images.
v0.1.45
Test thermostat class for Homey card behavior.
v0.1.44
Fix Norwegian text encoding and remove sync warning.
v0.1.43
UX cleanup: replaced the driver icon with the new heater symbol, switched sync-pending from alarm capability to a warning message, and improved pairing names for duplicate rooms.
v0.1.42
Description cleanup: removed the technical sentence about nominal watt syncing to keep the store text simpler and more user-focused.
v0.1.41
Store description update: expanded the app text with migration steps from the official Adax app, API credential setup, and realistic expectations for REST-based control and sync delays.
v0.1.40
Device image update: replaced the Adax WiFi Clea/Neo product artwork with the exact user-supplied heater image for driver small/large images.
v0.1.39
Device icon polish: refined the heater mask proportions to better match the slim official Adax panel icon in Homey tiles.
v0.1.38
Hotfix: made Adax energy_log sync non-blocking so temporary 5xx errors no longer make an otherwise healthy heater unavailable.
v0.1.37
Resilience update: transient Adax 5xx sync errors now keep the last known device state and only mark the device unavailable after repeated failures.
v0.1.36
Flow icon polish: made the heater outline larger, thinner and slightly more angled to better match the official Adax icon proportions.
v0.1.35
Flow icon polish: slimmed down the heater mask outline to better match the official Adax Homey icon style.
v0.1.34
Flow icon sizing fix: enlarged the heater mask silhouette and left edge so it survives Homey small-circle mask rendering more reliably.
v0.1.33
Flow icon fix: replaced the small driver mask with a solid even-odd heater silhouette for clearer rendering in Homey blue icon circles.
v0.1.32
Energy + sync update: meter_power now follows Adax energy_log data, while Homey keeps simulated live watts and shows a temporary sync-pending indicator after writes.
v0.1.31
Optimistic UI update: Homey now keeps target temperature and expected heating state locally after successful writes while waiting for slower Adax cloud state to catch up.
v0.1.29
Responsiveness update: reduced default polling to 10 seconds and added fast post-control sync retries after writes.
v0.1.28
Insights + icon update: added estimated cumulative energy (meter_power) and upgraded the driver SVG icon to a larger Homey-style monochrome heater mask for flow cards.
v0.1.26
Control debug build: added multiple Adax control payload fallbacks and detailed [Adax] logs for accepted/rejected writes and polling sync.
v0.1.25
Visual refresh: updated the Adax WiFi Clea/Neo device artwork to a heater-style product image and strengthened the monochrome flow/device icon mask.
v0.1.24
Control and diagnostics update: added control fallbacks, sync/poll logs, and a cleaner monochrome heater outline icon.
v0.1.23
Driver icon fix: replaced the room device icon with a mask-friendly monochrome heater glyph for Homey pairing cards.
v0.1.22
Pair navigation fix: list_devices now explicitly continues to add_devices after room selection.
v0.1.21
Pairing list now sorts rooms by Adax home and prefixes device names with home name when available.
v0.1.20
Updated Adax WiFi Clea/Neo device icon to match the official panel-heater style.
v0.1.19
Pair flow fix: added missing add_devices template step after list_devices so selected rooms can be added.
v0.1.18
Pairing robustness update: dynamic Homey API detection/loader for web pairing contexts where Homey.emit was unavailable.
v0.1.17
Web pairing fix: removed incorrect data-origin on /homey.js causing Homey.emit to be unavailable in Add Device flow.
v0.1.16
Pairing hotfix: switched credentials submit to promise-based Homey.emit with callback fallback to avoid silent Continue lockups.
v0.1.15
Fixed pairing credentials step: corrected Homey driver origin and improved submit/error handling.
v0.1.14
Updated app description text to English with private developer disclaimer and API usage clarification.
v0.1.13
Updated app description text (Norwegian) with private developer disclaimer and API usage clarification.
v0.1.12
Fixed Norwegian text encoding issues in app settings and hints.
v0.1.11
Cloud API hardening: strict /rest base, client token reuse, control status validation, and target temperature clamping.
v0.1.10
Locked non-header visuals to fixed reference layout; kept header mask icon unchanged.
v0.1.9
Unified all non-header visuals to the same ADAX + UNOFFICIAL reference style.
v0.1.8
Header icon uses red slash; restored all other images with UNOFFICIAL text.
v0.1.7
Refined mask icon for cleaner header rendering.
v0.1.6
Mask-compatible app icon for Homey header rendering.
v0.1.5
Minimal standards-compliant app icon test for Homey header rendering.
v0.1.4
Failsafe app icon format for Homey header rendering.
v0.1.3
Robust app icon rendering fix for Homey app header and listing.
v0.1.2
Safe app icon update for correct rendering in app header and listing.
v0.1.1
Icon and image consistency update. Improved app visuals and metadata polish.
v0.1.0
Initial release: Adax WiFi Clea/Neo support with estimated power logic and automatic nominal watt sync from Adax API.
Older notes are condensed; all listed versions, including temporary v2.0.0, are retained. Post 1 explains optional sharing and support.
I get this message:
Hi Jacques! It looks like the Adax account ID field contains “Service 2”. This needs to be your account ID, not the name you gave the API integration.
In the Adax app, go to Account → Third-party integration / External API and create an API password. Then enter your account ID and that generated password in the Homey app settings and press Save. Use the API password, rather than your normal Adax login password.
Let me know if that helps :slightly_smiling_face:
v0.3.63 — App description restored
The full English App Store description is back, including setup instructions, the power and energy explanation, external temperature sensors and limitations. The Community link stays in place.
This is a documentation update; heater control and energy calculations are unchanged. The build has been uploaded to the Homey Developer Portal. App Store and test-channel availability may follow later.
v0.3.64 — Support through this topic
The App Store support link now points to this Community topic. The English app description also explains where to ask for help if you have problems or questions. The full setup instructions and technical information remain in the description.
No changes to heater control or energy calculations. The build has been uploaded to the Homey Developer Portal; App Store and test-channel availability may follow later.
Yes, works fine now. Thank you.
v0.3.65 — Explain the power estimate
Optional diagnostic sharing can now include why the app chose its watt estimate, when that decision was made, the temperature and setpoint used, internal/external temperature source, offset, hysteresis and whether an earlier estimate was retained. The explanation keeps its own timestamp, separate from the cloud observation.
This helps investigate cases where estimated watts differ substantially from cloud energy. It does not fix or recalibrate the estimate yet, and is not a physical measurement of heating. Heater controls, energy calculations and Adax polling frequency are unchanged.
Sharing remains optional and off by default. No sensor names, account credentials or extra Adax requests are added. The settings and privacy information explain the diagnostic fields. Earlier observations simply have no explanation; new context appears after installing this version and subsequent scheduled uploads.
Build 237 has been uploaded to the Homey Developer Portal. App Store and test-channel availability may follow later.
v0.3.66 – passive comparison and clearer uncertainty
This update adds a passive comparison of internal-temperature watt estimates without the display temperature offset. It helps us investigate differences in the estimates while leaving live watts, heater control, energy accounting and Adax polling unchanged. External-temperature behavior is unchanged.
Long-retained estimates are now explicitly marked uncertain after 30 minutes in device diagnostics. For people who have opted into diagnostic sharing, the admin dashboard also summarizes model differences and observation coverage, with a filter for rooms that need a closer look. Missing observations and unknown candidate estimates remain visible as such. These are diagnostic indicators, not physical power measurements.
The temperature-adjustment setting now explains that the current live model also uses this offset. The passive candidate does not change that model. Diagnostic sharing is still optional and off by default.
v0.3.66 is now available as an app update (Build 238). Please update the app to receive the new diagnostics. The new comparison requires observations from v0.3.66; older data cannot supply it.
The setup guide in the first post and the consolidated version history above have also been updated.
v0.3.67 – Norwegian and English in the app
App settings now follow the language selected in Homey, with Norwegian and English available. The update also translates supported diagnostic status messages, pairing guidance and Flow validation errors. The existing Norwegian and English device settings and Flow cards are retained.
The full App Store description stays in English, including on the Norwegian storefront. This Community topic and release notes also stay in English. Raw JSON logs, API field names and upstream error details remain technical.
This is a language update. Heater control, power estimation, energy accounting and Adax polling are unchanged. Diagnostic sharing remains optional and off by default.
Uploaded to the Homey Developer Portal as Build 239. App Store/test channel availability has not yet been confirmed. Once installed, the app uses your Homey language setting; no separate app language selection is needed.
v0.3.71 – drawn heater artwork and App Store summary
The driver image is now a flat, drawn heater symbol on white. The heat waves follow the panel perspective, getting larger toward the nearer side. It has no realistic surface, shading or depth effects. Both required image sizes are included. This replaces the intermediate artwork from the preceding builds.
The English App Store description is now a short two-paragraph summary. Full setup instructions, technical explanations and limitations remain in the first post of this topic, through the app’s Support and Community links.
This update changes presentation only. Norwegian and English support, heater control, power estimation, energy accounting and Adax polling are unchanged.
Uploaded to the Homey Developer Portal as Build 243. App Store/test-channel availability has not yet been verified.
28 October 2026 – v0.3.72 and diagnostic comparisons
v0.3.72 (Build 244) is live in the App Store. It went live on 26 October; I have now checked the release status and both of my own Homeys are running it.
Internal Adax power estimates now use the unadjusted internal temperature. Your temperature adjustment still applies to the display; external Flow temperature behavior is preserved. Internal input expires 15 minutes after receipt, while external input uses its configured maximum age. When the app lacks valid input, it shows unknown watts after bounded command handling and leaves a gap in local energy until cloud data covers the period.
The release also adds a passive average-power candidate near the setpoint and energy comparisons from before cloud correction. The candidate is uncalibrated and does not control heating or the live watt value. The available observations do not yet justify replacing the current model.
Today I updated the diagnostic admin view to compare the same fully covered periods for both models. Repeated observations are deduplicated, overlapping periods are excluded from totals, and explicit energy_log intervals are distinguished from provisional withEnergy windows. These remain estimates compared with cloud history, not independent physical measurements. This admin change requires no new app update.
Diagnostic sharing remains optional and off by default. Heater commands and Adax polling are unchanged. Some rooms still receive HTTP 502 from Adax energy_log; the existing backoff remains in place.
The setup guide and consolidated version history in the first two posts have been updated.
App Store · Test link
31 October 2026 – CPU and stability updates
v0.3.86 (Build 253) is now available in test and installed on both of my Homeys. It includes automatic lossless compact history from v0.3.84 and the new optional error/possible-crash reporting. Stable remains v0.3.72. Build 253 has been submitted for certification and is under review, with automatic publication after approval enabled. The v0.3.83 certification submission was retracted because Homey blocks newer test releases while another build is under review. v0.3.85 was an uploaded draft only, superseded by 86.
The main CPU finding was that changing one device-store key sends the entire device store. Repeated full energy checkpoints, obsolete mirror writes and large history copies therefore cost more than they looked. The updates remove repeated work and use a compact history format that preserves every timestamp and Wh value. One-time conversions run one room at a time; minute accounting remains every 60 seconds.
In a same-code comparison on v0.3.83, I switched from legacy to compact storage without restarting either app. Each 15-minute window had 181 samples per Homey and excluded the conversion itself. Circus went from 15.86% to 12.57% average app CPU, and Mattis from 14.92% to 8.51%. The combined average was about 31.5% lower. These are short local windows, not a guarantee for other households. Peaks and CPU warnings remain; no crash was registered. Earlier cleanup had already reduced the initial combined average from roughly 27% to 15% in different windows; these percentages should not be added.
The next v0.3.84 update verified both upgrade paths: Mattis automatically converted six legacy rooms, while Circus retained eight compact rooms through the update. All 14 rooms reported readable history with no unfinished cleanup. A later 15-minute window, at least five minutes after startup, averaged 12.12% and 8.23%. Both apps stayed running and completed the regular heartbeat cycle.
Heater commands, Flow behavior, temperature-source priority, estimation models, energy-accounting rules, history retention and Adax polling are unchanged. 155 app tests and 16 admin tests pass, including interrupted migration, restart and energy replay, control registration with unreadable history, consent and failure isolation.
Voluntary participation now explicitly includes logging errors and possible crashes. Read the updated disclosure and save your sharing choice again to enable the new categories; existing consent does not enable them automatically. Reports include only fixed error categories, times and app version, plus previous startup time if no exit was observed. Raw error messages, stacks and file paths are excluded. A missing exit can also follow a normal restart, update or power loss; its cause is unknown. Abrupt termination may leave no final report.
The runtime observer preserves Homey’s process handling. There is no new CPU sampling loop or automatic restart. Sharing remains optional and off by default. The existing outbox keeps at most eight pending health events for two days, with urgent uploads at most once per minute. Withdrawal clears pending uploads and requests server deletion.
Test version · Stable version
1 November 2026 – clearer diagnostics and support
v0.3.87 (Build 254) is available in test. It includes the previous CPU/compact-history work and adds clearer diagnostics without changing heater commands, Flow, power estimation, energy accounting, polling or voluntary-sharing consent. Both own Homeys now run the signed test build: all 14 rooms are available, compact history remains readable and meters have not decreased. The new protected diagnostics endpoints work on both and support reports exclude their room names. Stable remains v0.3.72. The earlier v0.3.86 certification submission was retracted to allow this newer test build; v0.3.87 is now under certification review, with automatic publication after approval enabled.
App settings now show consumption-source quality for each room and selected period: local estimates, provisional cloud data with inferred time bounds, energy-log cloud data, mixed sources, missing coverage or limited historical provenance. This reads recent saved accounting periods on demand. Older totals can remain available even when detailed source history has expired; the latest minute may await its normal checkpoint. Allocation within a cloud period may be estimated. These labels do not certify physical accuracy or change energy totals.
Control Health separates control, sync and runtime error events. The counts use the retained runtime snapshot, up to 250 events within the last 24 hours; older errors may be absent. They are event counts, not a failed-command rate.
A manual support-report button prepares a report for review and copying. It contains app version, hardware family, an optional selected Homey model, room count and fixed error/source states. Names, IDs, credentials, temperatures, consumption values and raw errors are excluded. The report is not uploaded automatically, remains visible for manual copying, and does not change diagnostic-sharing consent.
163 app tests pass. Added checks cover source provenance and incomplete history, non-mutating diagnostic reads during pending repair, report privacy, token-refresh recovery after expired credentials/network failure, avoiding blind control retries after HTTP 502, and deleting a partially initialized room while work is pending. Synthetic Norwegian/English/fallback and mobile UI checks passed; automatic clipboard contents could not be independently verified through the browser tool, so the report preview also supports manual copying.
Test version
2 November 2026 – fewer repeated background writes
v0.3.88 (Build255) is approved and available in the stable channel, as well as test. This is a focused background optimization: five withEnergy metadata fields are written only when their individual values change. Every cloud response is still processed, including energy reconciliation, simulated consumption, comparisons, diagnostics and voluntary reporting. Heater commands, Flow and polling intervals are unchanged.
A repeated-response regression test reduces seven store calls to two with identical persisted results. This is a storage-call count, not a claim of a particular CPU reduction. Failed writes are retried even if the Homey SDK already exposes the rejected value in memory. All 167 app tests pass, including recovery, control and accounting checks. The signed test build is installed on both developer Homeys: all14rooms remain available, meters have not decreased, compact history and diagnostics are readable, and existing voluntary uploads/error reporting still work. No new failure events were observed in the initial check. The previous0.3.87review was retracted to allow this build.
Status update 4 November 2026: certification is complete and v0.3.88 is Live, replacing v0.3.72 in the stable channel. The Developer Portal records the Live status update on 3 November at 16:02 CET.
Test version
