[APP] Philips Smart Devices - Add your Philips smart devices to the Homey ecosystem
Then I’ll convert to ssdp
Please test v.1.2.2
I can now find and add them :slight_smile:
Its hard to distinct between them on adding, they all get the same name, in this discovery method you get a friendly name. Or/and seeing a mac in the settings would also help out :wink:
Ill give the features a test run now :slight_smile:
That long list of buttons, where do the time slots come from?
OK first test, checking status seems to kind of work.
But it is extremely unstable, both the Philips sleepmapper app as the homey app are both crashing the connection every couple of seconds. I think your are overloading the connection.
When your app is active the Sleepmapper app itself often fails to connect and gives me a reset your device due to an issue error.
The sleeptracker workflow event also isnt fireing but that could be caused by the unstability
It’s exactly the alarm clocks from the device
Yes I am working on this problem, found a solution with event subscribers, digging in that area
I will add some ID’s
Hi @Kaoh, please test new fixed version: Philips Smart Devices App for Homey | Homey
Looks to be more stable, not crashing the mobile sleepmapper app also anymore.
Ill play with it some more :+1:t2:
Very good first impression.
Seems the status is not syncing always, i started a sleep tracking from the light and it did not send to toglle the button.
A wish: the insights in the history shows a lot of on/offs, would be nice to see them for the tracking on etc
Regarding synchronisation of statuses and buttons, please look at advanced settings. Everything is described there.
I don’t quite understand about insights, as far as I know they can be switched on and off in the application, can’t they?
Ill check those, maybe i changed them during the previous version.
The insights i mean this
There were different switches. Main light, sleep tracking etc. But they all show with the same entry of on/off
The polling is set to 10 sec.
But no update on my disabled tracking
72410935-4646-458c-b964-1ad319d794d1
  1. Use the alarm clock itself to activate and deactivate bed tracking. You need to hold the touch button on top of the alarm clock. Or via the Homey or Flow app.
  2. You need to uninstall the device and install it again in Homey, there have been major changes in the app. The problem could also be with this.
You can also go to the developer’s tools and see if the status of the device itself changes. I noticed a strange bug that statuses can change, but they are not displayed in the app. It seems to be a bug in the Homey app itself.
I’ll see what I can do, please create an issue on github
Question, my homey can’t find my Philips Wake up light.
What can i do to set this up?
What version of the app are you using?
I’m on version 1.3.0
Can you please send the following request to your device and forward me the response:
http://your_device_host/upnp/description.xml
or
https://your_device_host/upnp/description.xml
a00d7329-5c1a-4546-a1ec-f4c7b5174b57
See diagnostic report. It keeps missing my sleep tracking mode events.
