[APP][PRO] Oss
Homey app to integrate to your Oss.no - chip from https://oss.no/
You will have access to your current power usage and total consumption.
Requires access to the Internet. Values are refreshed once per minute.
Installation:
  • Add the “Oss-Chip” device.
  • First step: Enter the email address you use for Oss.no.
  • Second step: You will receive an email from Oss.no. Now enter the code that you got in the email.
  • Third step: Enter the meter ID for the AMS - meter the Oss.no - chip is plugged into. You will find the 16 digit meter id on the front of your AMS meter.
It might take a couple of minutes before you can see the values.
Changelog:
0.9.2
  • Added triggers for ‘Consumption yesterday changed’ and ‘Consumption today changed’.
  • Avoid zero result from Oss.no API.
0.9.1
  • Power usage for yesterday and today.
  • Added API that can be used for showing power usage on a Lametric smart clock.
0.9.0
  • First version for app store.
Thanks, Nice job!
Possible to CLI install? Don`t find it on your Github, currently 0.9.0 is in store, thx!
I want some feedback first, then update app store with 0.9.2.
Even positive feedback is nice to get :slight_smile:
I will, still waiting for Oss, they said 2-3 hours after first connection, will give you som feedback this evening!
Happy to see the Oss-app as requested in app requests, thanks to Bjørnar Amli!
Currently I combine Tibber and Oss via a splitter connected to the HAN-port, still waiting for Oss to update, a bit unsure of the Oss update frequency and accuracy, we will see :slight_smile:
Still a nice addition to MQTT data, since Oss have a couple of datasets Tibber has not.
0.9.2 is in app store as a test-version:
https://homey.app/a/no.oss/test/
Great work, thank you!
I was testing their node examples on GitHub yesterday, revisiting the RPi Zero installed in my fuse panel.
It seems their example code isn’t working anymore, so I gave up. Then I now randomly came over their blog from yesterday, rendering my RPi solution obsolete :sweat_smile:
The yesterday/today parameters, are they from Oss.no? Because what would be interesting IMHO is to compare two days ago + yesterday, so you’d know if you used more or less power than normal (of course possible to do this with variables/logic).
Yes, both yesterday and today parameters are from Oss. Today is updated once each hour.
Ok, perfect.
Then I’ll play around with variables and mosquitto for sending stats to a Nextion display :slight_smile:
Thanks again, I’ve been waiting for this since I installed my RPi (which hasn’t really done anything useful yet).
Might still re-revisit that to get constant offline values though.
I am trying to add my OSS-chip to Homey, but recieve an error-message after entering my registered e-mail in Step 1: “Invalid authentication. Try again”
Any Solution to this?
Might be some error with Oss-services right now.
Maybe you can try again in a few hours ?
You can test yourself from this Swagger API site:
https://api.services.oss.no/swagger/index.html
The /api/Auth - endpoint, with your email - address
Any chance to make the powermeter support two Ethernet connections? Have Tibber Connected, but would like Oss also, does not work with RJ45 split, or switch.
I have no affiliation with the company Oss, that makes the Oss - chip.
I’ve had two power meters connected to the HAN power with a RJ45 splitter myself: Oss and Puls (from Fjordkraft), and that worked well.
That is interesting, what kind of splitter?
Just a simple splitter, purchased from Aliexpress.
I get error code 500 and the message: {“errorMessage”: “The email request was not accepted”}
The Oss-api might be offline right now. Try again later :slight_smile:
Yepp, have been trying for several days now. So I contacted OSS about the API, and that was the problem. They fixed it and the app is working now. Thank you! :slight_smile:
