[APP] iRobot - So you can human
Central topic for questions/discussing the iRobot App. You can use this topic to ask questions and share your experiences with the devices from iRobot.
This thread is not actively monitored by iRobot Corporation or Drenso. For official support use the e-mail link in the AppStore Support Contact ».
My Roomba j7+ was replaced under warranty with a Roomba Max 705. The Max 705 uses a different app
Although I can add it to Homey, control from Homey seems to be limited. In particular, it no longer seems possible to use the Start Favorite flow card.
In other words, I can only initiate a mission to vacuum the whole house, whereas I need to be able to specify which rooms need to be vacuumed.
Any ideas on how I can accomplish this?
Anyone been able to successfully add devices using this app? Not much guidance on setup and when logging in to add device shows no devices found. API issue?
Wonder if could be possible to add to the application event when Roomba is stuck. Strange that even mode change does not have mode for that. Though, IFTTT integratio somehow detects it.
