@mapulu
Thanks that would be excellent! Timeframe is not an issue
Let me know what and when I can do to help.
Post canāt be empty
Sorry for the delayed reply, havenāt been home
Thanks for giving it a try!
Send me a pm if you need some testing done on the ptz cam.
Hi guys,
Iām trying to add my new Hikvision cams, but nothing happens when i press connect.
Post canāt be empty
Tried different IPās and ports. But the āāconnectāā button dont work. It looks like the button is not working. I can only click the āātestāā button.
@MRK: Does the ip and port combination work when connecting to the camera via web browser? Which protocols do you have enabled on the camera? (Http/https?)
@mapulu Iām having some troubles getting snapshots from my 4K (8mp) cameras. Have been using the app in combination with my 4mp ptz camera and alarm streams of all cameras to great success (via nvr)
When making a snapshot of one of the 8mp cameras Iām getting an image buffer error (see screenshot)
Can get a snapshot of the cameras directly (via virtual server of nvr) using the app and virtual ip camera function.
Iām probably doing something wrong with the settings of nvr, do you have any tips?
My cameras:
DS-2DE2A404IW-DE3 (PTZ-camera)
3x DS-2CD2185FWD-IS
NVR:
DS-7608NI-K2 / 8P
Iāts working now. Thanks to maplulu for some help by DM. I tried the wrong ipā¦
Hi, is any list compatible product, or model class ? I want buy some HIK cam, + NVR, which NVR is supported? if possible use WHI-B120 CAM? or NVR other series then DS (HWD or HWN)?
If possible use ANALOG/ip cam (no easyIP) with NVR <> Homey (alert, flow, and other with this app) no direct connection to cam, only to NVR (with ehernet).
Thx
Hi, it was working fine until Iāve upgraded the firmware on my NVR, not it is sort of clunkyā¦
I wondered if anyone else had the same issue?
In particular, I used to be able to receive alarm signals - but not anymore?
What is your model and software version of the nvr? (To inform other users of hivison nvrās)
On the
DS-7716NI-I4/16P
V4.21.007
Alarmtriggers donāt work.
Hi Mapulu,
Thanks for your work. I tried to duplicate your 3 flows, but don`t have all the tags. Is there something I do wrong?
I only get these:
Any help would be nice
Did you get a reply to this? In the thread now I mostly see lots of āPost canāt be emptyā
Isnāt possible at the moment. Its complicated and have to double check that there is no error because wrong commands can crash your device.
Hi there,
I have been using the app for a couple of months now. Love it!
Just a question: I noticed that the line crossing notification via homey does not always work. My hikvision app consistently reports line crossing, but I do not always get a corresponding notification via Homey. Is this a know issue or are there any settings I should change?
Thanks!
I have the same issue, ive also contacted @mapulu about it so I hope he can solve this problem at some time
since im also using it for visitor reporting and setting the outdoor lights
Does this integration support the Hikvision wifi doorbell DS-KB6403-WIP?
fe. when someone pressed the button I can start a flow to activate a chime, lights, etcā¦
I have installed the app but when I try to add a device and hit test or connect it crashes your app.
I have submitted a crash report.
All my hikvision camās are connected via nvr and nvr to homey, works perfectly. Only doorbell integration missing.
