App for 868 Mhz weather sensors
Is there an app supporting weather sonsors communicating via 868 MHz?
I would like to have an answer too! :pray:
Try “wireless weather sensor”
Really not sure, you’ll have to test
In the protocol selection there are only 433 Mhz protocols availble, no one for 868 Mhz. A test with all available protocols wasn’t successfull.
I believe at this stage its rather important that you give the brand and model of your 868 MHz weather sensors
I can only select the protocol in the app. There is no model. I selected TFA for Dostmann but nothing was detected. Where can I choose brand and model? I use version 2.5.2.
Please give the brand and modell type of your weather sensor, of the physical plastic devices you are holding in your hands
Then we can look for an app
It is a TFA Dostmann/Wertheim STRATOS (35.1077) with a T/H-transmitter (30.3151), a rain gauge (30.3152), and a wind transmitter (30.3153). The numbers seems to be item number only.
Have you already had the opportunity to look for a suitable app?
I’ve got a Bresser weather center 5 in 1 working with 868 Mhz.
Homey has 868 Mhz controller, but why if there is no app to use it ?
Z-Wave is working on 868Mhz
I know, but it’s not the purpose.
Homey support has sent this reply :
“At the moment, there is no Bresser app available for Homey Pro so it is not possible to add your weather station to your Homey Pro.
I would recommend you to reach out to Bresser, and inform if they plan on releasing a Homey App. Homey is an open platform, so these brands can simply jump in and create this integration. The more people send in requests, the faster this process goes, so your message will always help!”
I already wrote to Bresser, but need more users to write…
