[APP] Easee charger - Small. Smart. Full of power
You did install the test version right? As we do not frequent this forum, please make sure to email our support address and include the app diagnostics code in your message: hopefully we can see what is exactly going wrong in your setup. Also, make sure to include whether the charger is working as it should with the v2 test version.
EDIT: I missed that you upgrade it to 2.0.1 , that version works fine
Equalizer does not work since yesterday, I think this is for everyone. chargers work.
EQ works now on V2.0.1​:+1:
@Jampe_Uppgard I assume you mean it doesn’t work with version 1.10.0, but that it does work now with 2.0.1, right?
Yes. V 2.0.1 works.
2.0.0 broken equalizer
Den ons 2 sep. 2026 14:56Drenso V.O.F. <notifications@athom.discoursemail.com> skrev:
Did you guys change anything else significate in the latest version? I have a trigger to notify me when connecting vehicle. Well actually when state changes on charger and its anything but standby is how I have to do it nowdays but its alot faster to notify now. I mean earlier it could be a minute now its within a second or two.
Actually noticed it’s still broken, update on EQ might happen every few minutes which is useless. then and the chargers was stuck from 5 to 7.30 with pasued status when car was disconnected.
If you experience any issue please use our official support email channel: that way we can personally assist you and hopefully resolve the issues you are experiencing.
I did. Sent a diagnostic this morning as requested. Havent heard anything since
I also see the same problem here - Charger state and data does not update.
(e-mail sent to drenso with diagnostic ID).
Same problem here. Status and data aren’t updating. The charger thinks the car is connected, but I’m 200 km away from the charger and have the car with me :slight_smile:
Here it also stopped working. I had set a flow that when a cable gets connected it checks whether I’m home or my wife is and if so then charging would start automatically.
Now it sits “waiting for approval” in the Easee App while the status in the flow still use “Waiting for Authentication”
it will only start when I manually approve via the App or use a RFID card.
EDIT
Diagnostics report send: a4a350bb-96c0-418d-8e57-0f8f18de6f15
why do they even bother, take over the app, fuck it up then leave. was working fine for years when Richard was dev. First update and nothing works
Since the update I don’t get current/watt report to homey. That messes up my flows, I did send an email about this. I deleted the charger and added it back in homey. Works for some hours then same problem again. Need a fix
It’s completely broken with the first update in since the takeover in february and they don’t seem to care,
If you want the charger status to update you need to restart the app, that’s the only way to trigger it.
Same here. The app is broken with latest changes in v2.0. Currently on 2.0.1 and none of my flows work. Charger status is stuck on “Awaiting authentication”. I have to manually authenticate via Easee IOS app or the turn click the “ON” button in the Homey App tile. Here’s a screenshot of the Homey app (while the charger is charging my car). Seems like there is no data coming in/out.
Same for me, my charger is more or less useless at the moment.
Same for me :sad_but_relieved_face:
I got a response from Drenso, they are aware of the issue, working on it and “will release a fix next week at the earliest”.
Exactly the same respond I got. Hope they fix it soon
