[App] DEVIreg™ ZigBee
I’ve made an app for the new Zigbee compatible floor-heating thermostats from DEVI, so they can be used directly with Homey without the DEVI provided Connect gateway and app.
DEVIreg™ Connect
For now it supports the DEVIreg™ Display Connect thermostat.
Setting up the thermostat should still be done over BLE following the manufacturers instructions.
Then you switch it to ZigBee mode by holding down the reset button until the connection icon flashes purple, and follow the instructions in the pairing procedure of this Homey App.
If you’d like to test the app it is awaiting certification but can be found here in a test edition.
I assume no responsibility for your heating system. You need to make sure the thermostat is set up to match the limits of your floor type. This is something your installer, or you, should do via the DEVI bluetooth app.
@Doekse I’m trying to get in touch with DEVI, they’re the electrical heating division of Danfoss here in Denmark, and I’d love for this to evolve into an official app.
I was already in touch with DEVI back in October about an official integration, I’ll nudge them with your app and have a look if I can get you in touch :wink:
Well, I’m up for hire :wink: - en ik spreek nederlands ook.
Been a dev for 20 years and this is my first Homey app.
It was a breeze to do. Really, I was surprised about your API and CLI, it’s blazingly easy to do stuff, like this with a straightforward ZigBee device - even when there’s custom ZigBee attributes to figure out… I mean it took a day to get to 1.0 - without me having read your docs before.
So hats off…
I already got an email back from DEVI! Please shoot me an email at partners@athom.com and we’ll be in touch.
Fijne avond :wink:
Is it possible to set the temperature lower than 15 degrees? The thermostat will not accept and go back to 15, if I try.
Hi
Yes, i had the same problem. Talked to the DEVI people and they’ve released a firmware update.
Use the DEVI Bluetooth app to update.
It will then accept down to 5.0 degrees celsius.
