App creation for HomeWhiz support (Beko / Grundig)
With ‘16 tiles’ you mwan 16 devies, one for every sensor?
Just use one device (on/off switch or what’s your primary control.
Then go to device settings/repair. select “add entity”. Then search the sensors and add them one by one.
Or if all sensors are part of the same HA device, go to device settings and check the sensor checkbox.
Start with this post and check both links inside. I hope this will guide you how to build your custom devices :wink:
