[App] Connect All Zigbee - Seamless Smart Home Connectivity with Zigbee
This app works only ThinQ ON!
Connect smart lights, sensors, switches, and more with the Connect All Zigbee app.
Use the Zigbee open-source library to add a wide range of Zigbee devices.
Start enjoying a smarter life with Connect All Zigbee.
So the ThinQ ON does not require separate apps for Zigbee devices?
I bet a lot of Homey users would also be very happy with such a feature.
So this is a non-Homey app?
Shouldn’t your post have a link to the app?
And why is it on a Homey forum?
Genuine question, no offense, of course.
Do Homey and ThinQ ON share the same apps?
Thank you for your concern.
Homey and ThinQ ON share almost the same apps — about 99% of them are the same.
Thanks.
Could you explain what this app can do? or how to make a connection of zigbee devices?
This is the app page shown in ThinQ app. As shown in the screenshot, the app is powered by Homey. I do not own a ThinQ On hub, so cannot describe my experience with it. However, based on the user experiences reported in a Korean (obviously South ;-)) community, it connects to various zigbee devices, lights, curtain motors, and etc. that are purchased from aliexpress.
Since both ThinQ On and Homey shares almost identical h/w and s/w base, there’s no reason why Homey cannot support the app, IMHO. Hope homey adopts the app soon.
The Connect All Zigbee app can be installed on ThinQ ON and utilizes the open-source library from Zigbee2MQTT to expand Zigbee device connectivity. With this app, you can easily and quickly connect and control Zigbee-based smart home devices. Additionally, it offers high compatibility with a wide range of devices that support the Zigbee standard, making smart home setup more convenient.
:slightly_smiling_face:
Thank you for your interest in the app and for your thoughtful inquiry.
To directly address your question: The app is currently available on ThinQ ON. As for its implementation on Homey, we are actively evaluating the possibility, though it may require some additional time to complete the integration process. We appreciate your patience and interest in this matter.
Thank you for your understanding and continued support.:slightly_smiling_face:
So LG ThinQ apps and Homey apps are different? I thought those were the same. Are all the regular Homey apps also available on the ThinQ ON?
I thought they were the same, but I now realize that the app release and store can differ — the Homey Store for Homey Pro and the ThinQ Play for ThinQ ON. I’m not sure what the difference is between them. I hope that users of Homey Pro will be able to use this app soon.
Thank you.
Can you provide a link to that?
and are ThinQ ON users accessing the Homey App Store (fe Korean Holiday | Homey )
or directed to another place where the ThinQ ON version of “Homey” apps are published?
You can access this app’s link using ThinQ App!
Thanks.
(post deleted by author)
I am a user of the LG ThinQ ON Hub in South Korea. I am currently using your “Connect All Zigbee” app and very impressed with its performance.
Thanks to your app, I have successfully integrated and using the following devices:
MOES 4-Gang Switch
Tuya Curtain Motor V3
Aqara T2 Bulb & T2 Pro Downlight
Aqara P1 Door Sensor
Philips Hue Lightbar
However, I found that the Aqara WXKG15LM (H1 Wireless Switch) and Aqara WXKG11LM (Mini Switch) are currently not recognized or supported in the current version (v1.1.3).
Since these devices are already officially supported in the Zigbee2MQTT (Z2M) main repository, I was wondering if it would be possible to update the app to include the handlers/fingerprints for these models.
Requesting Models:
1. Aqara H1 Wireless Remote Switch (Single) - WXKG15LM
2. Aqara Wireless Mini Switch - WXKG11LM
Having these devices supported would make my smart home setup perfect. Thank you for your hard work on this app, and I look forward to your positive response!
Hi @Lee_SW,
Thank you for your concern about our app.
The models you mentioned should be supported in our app, but we couldn’t test those devices because we don’t have them.
Alternatively, you can use the Aqara app instead. Can you check them using the Aqara app?
Please let me know if you have any more questions.
Thank you.
Connect All Zigbee Team.
