Can you check what the Zigbee product ID of the product is? You can find it under Settings in the app.
I found a bug in the code. I’ll get it updated. But if you select the Wally sensor, it should work. Only the icon will be different. the functionality is the same.
Then I’ve tested version 1.1.54 and I’m able to add the stoveguard as expected ![]()
I notice I’m no longer able to turn the guard on/off direcly by pushing the “button”, although the setting “Aktivere styring av rele via OnOff” is on in the settings ?
EDIT !! Turning the setting on/off in the app solved the issue, I can now use the “button” as on/off as expected, so everything seems OK
Thanks !
