Smart (Components) Toolkit — v1.9.2 stable / v1.10.0 test
Full Documentation: Smart (Components) Toolkit for Homey
Replace complex flow networks with powerful logic devices controlled by dynamic formulas. Make your flows cleaner, more readable, and easier to maintain.
→ Full Documentation & Interactive Tools
New in test (v1.10.0): Circadian Light Group
A virtual light device that adjusts brightness and color temperature for a group of real lights — automatically following a circadian rhythm. Available now in the test channel only; the stable channel still ships v1.9.2 without this device.
Why use it?
- Bright cool light during the day, warm dim light in the evening, deep red at night to preserve melatonin and night vision.
- Works at any latitude — pick clock times, solar events, or lux-sensor thresholds per phase.
- Doesn’t turn lights on or off; it only adjusts already-on lights, so it never fights with your other automations.
Anchor modes (mix and match per phase)
| Mode | Description |
| Time | Fixed clock time (HH:MM). Best near the equator. |
| Solar event | Sunrise, sunset, civil/nautical/astronomical dawn/dusk, golden hour, blue hour, solar noon/midnight — with offset minutes and a polar fallback time. |
| Lux sensor | A real lux sensor crosses a configurable threshold (rising or falling). Falls back to a fixed time until the first crossing of the day. |
Light profile
- Per-phase dim and temperature with smooth interpolation between anchors.
- Red mode threshold: when the calculated temperature drops below the threshold, color-capable lights shift to red. Saturation scales with how deep below the threshold you are.
- Per-light tweaks: enable/disable, prewarm before on, allow red mode, min/max dim.
Outdoor light source
Choose how the device knows how bright it is outside:
- Astronomical (sun-elevation calculation)
- Homey lux sensor
- Open-Meteo / MET.no (radiation-based estimate)
- External value pushed from a Flow
24 new flow cards
Triggers: phase changed, red mode started/ended, paused/resumed, turned on/off, target changed, error, outdoor light requested. Plus an app-level “Solar event occurred” card with all 14 events + offset, usable from any flow.
Conditions: is in phase, red mode active, is paused, is on.
Actions: pause (sec/min/hour), pause until time, pause until solar event, resume, turn on/off/toggle, set red threshold, apply temporary state (override dim/temp/saturation/red — restored on next tick, perfect for testing or quick “moods”), force red mode (with optional duration), apply now, set outdoor lux.
→ Read full Circadian Light Group guide
→ Install v1.10.0 test version
What’s already in stable (v1.9.2)
| Device | Purpose |
| Logic Device | Boolean logic with visual wizard. Combine device states into TRUE/FALSE using formulas like A AND B. |
| Logic Unit | Advanced boolean logic with multiple formulas per device. JSON configuration. |
| State Device | Scene management — capture states at setup, apply with one action. |
| State Capture Device | Dynamic state capture at runtime. Push/pop stack for temporary changes, named slots, JSON backup/restore. |
| Flow Card (no device needed) | Purpose |
| Conditional Gates | Simple GO/NO GO flow control without variables or devices. |
| Waiter Gates | Pause flow until a device capability reaches a target value. |
| Evaluate Expression | Range checking and value mapping with AND/OR logic. |
Quick examples
Doorbell ring → push state, change lights, restore:
WHEN: Doorbell rings
THEN: Push current state to stack
THEN: Set all lights to 100%
THEN: Wait 5 minutes
THEN: Pop state (restore previous)
Conditional Gate gating two flows:
Flow 1 — WHEN: Motion sensor triggered
THEN: Modify Conditional Gate "allow_lights" → GO
Flow 2 — WHEN: Door opened
AND: Gate "allow_lights" is GO
THEN: Turn on lights
Waiter Gate waiting for temperature:
WHEN: Button pressed
THEN: Turn on coffee machine
THEN: Wait until coffee machine temperature ≥ 90°C (timeout 5 min)
→ YES: Send notification "Coffee ready!"
→ NO: Send notification "Coffee machine timeout"
Documentation
- Getting Started Guide
- Device Types Guide
- Circadian Light Group
(test only) - State Device
- State Capture Device
- Conditional Gates
- Waiter Gates
- Flow Cards Reference
Installation and Links
- Homey App Store (stable v1.9.2): Install Smart (Components) Toolkit
- Test channel (v1.10.0 — Circadian Light Group): Install test version
- GitHub Repo: github.com/tiwas/SmartComponentsToolkit
- Online Emulator: Boolean Logic Emulator
- Formula Builder: Formula Builder
Feedback & Support
Found a bug or have a suggestion? Please report it:
- GitHub Issues: Report here
- This Forum Thread: Reply below!
Test-channel feedback on Circadian Light Group is especially appreciated — that’s where polish happens before stable release.
Support the Project
If you find Smart (Components) Toolkit useful, consider supporting its development:
Smart (Components) Toolkit — Simplify complex logic, state management and circadian lighting in your Homey flows ![]()
