Anyone Using Zigbee Retrofit Blinds on Homey? Here’s Our Zemismart ZMP1 Test
We’ve been testing the Zemismart ZMP1 Zigbee Roller Shade Driver in a Homey Zigbee environment (Homey Pro) and wanted to share some practical integration notes for anyone working with smart shading setups.
This is a Zigbee-based retrofit motor designed to convert existing roller blinds into position-controlled smart shades.
:link: Pairing & Basic Control (Homey Zigbee)
Device pairs as a standard Zigbee endpoint and exposes position control (0–100%) in Homey.
Once added, Homey provides:
  • Percentage-based blind position control
  • Scene / flow integration (open, close, set position)
  • Basic state feedback
:gear: Configuration / Calibration Behavior
In practice, configuration is handled through device settings exposed after pairing.
Observed controllable parameters include:
  • Travel limit calibration (upper / lower endpoints)
  • Motor direction inversion (useful depending on installation orientation)
  • Position alignment adjustment after full calibration
:battery: Battery Reporting
Battery status is exposed as a standard Zigbee attribute and is visible inside Homey device settings.
  • Battery level reporting works in percentage format
  • Suitable for automation (low battery notification flows)
:globe_with_meridians: Additional Information
For anyone interested in hardware details, specifications, or installation information, more details can be found on our product page:
:backhand_index_pointing_right: https://www.zemismart.com/products/zmp1
:handshake: For Community Testers / Integrators
We also welcome experienced Homey users and smart home enthusiasts to contact us for professional testing and technical experience sharing.
Hi Zemismart, I have 6 of your ZM25Z chain motors and they work great, been using them for a few years.
Would it be possible to add the same features to the the ZM25Z motors. Like battery monitoring and 1 tap open and close.?
Would that be possible?
Many thanks
sorry, ZM25Z is our new 2N wiring required motor.
you may sent the wrong module number, could you send pic or order number to check
These are what I have
https://www.aliexpress.us/item/3256805847916457.html?invitationCode=UWZ2SzlVNnRLdzNac1pOZkgyVG5PTEJISHZuTEh0TmNhT1EvZGRQRTB3NGpmdlBzNkVmWTlBPT0&srcSns=sns_Copy&spreadType=socialShare&social_params=61512339789&bizType=ProductDetail&spreadCode=UWZ2SzlVNnRLdzNac1pOZkgyVG5PTEJISHZuTEh0TmNhT1EvZGRQRTB3NGpmdlBzNkVmWTlBPT0&aff_fcid=c716caf834a24e19a3b99c0a87344652-1778225046585-01040-_EGk0uSa&tt=MG&aff_fsk=_EGk0uSa&aff_platform=default&sk=_EGk0uSa&aff_trace_key=c716caf834a24e19a3b99c0a87344652-1778225046585-01040-_EGk0uSa&shareId=61512339789&businessType=ProductDetail&platform=AE&terminal_id=2ee642e4360c49a0b028cd6936ca2cc3&afSmartRedirect=y&gatewayAdapt=glo2usa4itemAdapt
They pair to homey as a ZM25Z which i believe is a roller shade motor.
hi,
Your requirement is that this motor can be connected to Homey, but you also want to add battery monitoring and a one-touch switch code that can be viewed in the Homey app.
am i right?
Hi, yeah that’s correct.
Thankyou
ok,i will try to feedback to our team.
There is also avmatter version right?
yes, we have matter version: MTP1,Zemismart Matter over Thread Built-in Battery Blind Driver Retrofit Roller Shade Motor HomeKit Google Home Assistant Smartthings App Siri Control Shipped from US,EU,CA,CHN
