Angle of external sun blades with Qubino Flush shutter
How to set an angle of slats of external sun blades with Qubino Flush shutter in the flow when reaching desired position ? I am only able to set one value in the flow (% of the position). Thanks.
AFAIK its not possible. Its not possible with fibaro roller shutters neither. You have to use relative dim level and position shutters based on that. E.g, when closed, then to open blades slightly, you increase relative dimm level by 2%.
It’s a bug or a feature?
Its the way how its implemented. Maybe one day…
