Aeotec NanoMote Quad
Have you checked if the flow is enabled?
You probably misunderstood me. Everything is fine.
Hi. Is it possible to add Trisensor as non-secure?
P.S.
Yes, use CLI method and edit com.aeotec-master\drivers\ZWA005\driver.compose.json
from this source https://github.com/Aeotec-Group/com.aeotec
Where i can download source code of 2.3.0 version? on github only 2.2.3 is available.
??? You mean v3.0.2!?
No i mean 2.3.0, current stable version for FW4
Why are you looking on GitHub for stable app versions??? The stable v2.3.0 is available in the App-Store.
I did not looked in the App-Store before, because this should be the first place for looking at Apps. So I thought the stable version is the v2.2.3. This was the reason why I asked.
To edit driver.compose.json and add Trisensor as non-secure device.
Ok, did not have your special requirement in mind, sorry.
Z-Wave devices (brand independent) can be included via the Fibaro App and the Walli Switch unsecure.
Really? How? Please give me little instructions.
Okay i just read it again and tried it and it’s works! I thought it’s only for Fibaro devices. THANK YOU.
– Install Fibaro App (if not already available)
– Choose: Devices -> + -> Fibaro -> Walli Switch -> Connect
– Press Action Button once of the TriSensor
While inclusion, the sensor must be located only a few centimeters away from Homey.
That’s it.
I didn’t tried it by myself with other manufacturer, but they say it works.
THANK YOU! It’s works with Aeotec devices.
