Having problems to add my new Aeotec Heavy Duty Switch Gen 5.
ZW078
ZW078-A
Its mounted and ready, when I go through the add / pairing guide it get stuck after pressing the action button the second time. Everything seems to work well from the unit, the red LED stops blinking and its seems to be paired in the network but the Homey app just goes to error, “Somethings wrong, try again later”
Any help here on what to do? Does the Aeotec App not support Gen 5 of the heavy duty switch? Seems like you have to choose between Gen5 and noone Gen5 on the other products.
Yes, if you upgrade to Homey Beta FW v5.x, maybe a lot of apps has to be updated too. The reason for that is, that Homey FW uses SDK3 and apps with SDK1 don’t work anymore.
Usually, the device is reset to factory settings during inclusion. Nevertheless, reset the device before inclusion.
It could also that the device is too far away from the Homey. Move Homey close to the device (extension cable, powerbank) and try again.
EDIT
I asked someone from Aeotec and he said, that the HDS Gen 5 is supported by the app.
