This category is created to show, and explain the working of specific Flows in homey.
Here is what I have, but looking for a better way/way that works.
Basically wanting to open most of the blinds at 8am UNLESS the outside light levels are less than 35 lumens, in that case open most of the blinds when light levels hit 35 lumens.
The remaining blinds open the same way but at the earliest at 09:00.
You should definitely try using the build in logic AND cards, and look at the current luminescence level with that, and have the time as trigger (8:00), instead of the luminescence becoming bigger then 35.
Of course you can also ad more condition cards like It is after Dawn (30) if it makes sense, what I cannot judge in your case.
Regarding the DayLight - Yes/No variable. Such variables make sense if you can use them in many flows. But only for this particular flow, it makes no sense. You need additional flows and an additional variable.
But this is only my personal opinion.
Seems I didn’t explain it well enough.
– Logic card X is not greater than y: How should this card work if it’s not triggered? The connecting lines from the trigger cards to the logic card are missing.
– The value of the logic card X is not greater than y: In my screenshot I explicitly pointed out that not the value 50 but 0.5 has to be entered.
I’m looking at this and thinking that this might be what I need. But I’m new to all of this and I don’t understand how let’s say the “#Position” logic card is created and related to my Ikea blinds?
Do I have to create all the logic cards from scratch or should there be pre-defined logic tags within the system? When I try to search in the logic section nothing appears.
