Adding the ProMini to my Bridge
Does adding the Pro Mini to my existing Homey Bridge, give me access to all the Apps presently available to the HomeyPro.
Dom
You Bridge doesn’t do much, the intelligence behind it is Homey cloud.
So you don’t add Homey mini to the Bridge, you’ll replace Homey cloud with Homey mini and add the Bride to the Homey mini…
Mind you, I don’t think there’s a way to migrate from Cloud to Mini (or Pro for that matter). You’ll kind of have to start from schratch…
That is NOT possible,
You can start either with as platform:
  • A Homey Cloud
  • A Homey Pro (Early 2023)
  • A Homey Pro mini
A Bridge can be added to all three platforms but only to One of them at a time and is an extra antenna / transmitter.
If you want your bridge to connect to Homey Pro mini, you need to start over with adding all devices and flows to your new "Homey Pro mini " and can add the bridge.
And then, you can install any app store app :wink:
Well, if it’s SDK3.
But it is clearly mentioned in the App Store on which Homey is supported by the app.
