Great! This works! Thank you!
@RoyWissenburg @Rens_Brandwijk i did everything i had to do. But when doing the tuya-cli wizard i stopped. Something is wrong with my idās. The third value i have to fill in is a āVirtual IDā of a device. In iot Tuya i went to devices and selected the id of an device. But this isnāt the good one. Anyone here to help?
Haha yeah sorry. I was pretty annoyed that it just didntāt work and had some deadlines on work (so forgot it a bitā¦) Now iāve got an motion sensor too from LSC (action) so want to try to connect it too in the app. That was my trigger to go back to the topic and react. I think I have some problems with my Package.json or my connection to Tuya IOT.
@RoyWissenburg for some reason it is working now⦠Donāt know why because i did the same thing as the other days. New project is adding LSC Smart movement sensor in Homey. Added it like the lamp in the TUYA app, but itās now showing in the homey app yet.
Ik heb de tuya app geĆÆnstalleerd, alles werkt, behalve het dimmer via een flow, hoe kan dit?
Ik kan wel dimmer via apparatenā¦
Help me out!
Fout in de Flow, en als je die laat zien, kan iemand je verder helpen.
As this is the English part of the forum, you and I should post in English.
Show your flow, so someone can tell whatās wrong.
Rens
where do I find the set up instructions as said by the App?
See the setup instructions for how to find the needed parameters.
Cheers.
Now I need to learn to read and understand Githubbianā¦
i hope there will be somebody who writes an app for Dummies like me.
Iām trying to add an LSC device (Smart LED) to Homey, therefore i followed the (somewere) above mentioned procedure https://github.com/codetheweb/tuyapi/blob/master/docs/SETUP.md
After some strugling i finaly came to step 6 to generate the nessecary input for the Tuya app in Homey. At this point it ends for me, i get an error (see below) and i have no idea what can be wrong.
Anybody an idea what can be wrong?
Device(s) failed to be registered!
Error: you donāt have access to this API
at OpenAPI._client.got_1.default.extend.hooks.afterResponse.response (/usr/local/lib/node_modules/@tuyapi/cli/node_modules/@tuyapi/link/node_modules/@tuyapi/openapi/dist/api.js:68:31)
at EventEmitter.emitter.on (/usr/local/lib/node_modules/@tuyapi/cli/node_modules/got/dist/source/as-promise.js:87:38)
at process._tickCallback (internal/process/next_tick.js:68:7)
Hi Guys,
There are new products on the market from Action store (NL)
Did someone already use these with homey?
Review from bright (in Dutch): https://youtu.be/GsoFQCUg2U4
Wird die Tuya App auch bald für die Bridge funktionieren?
Thereās 3 Tuya apps: Tuya, Tuya Cloud, Tuya Zigbee.
But, only Athom could answer your question.
support@athom.com
Hallo,
dürfte ich dich mal fragen, wie du die normalen Glühbirnen A60 mit der Fernbedienung verbunden hast? Das klappt bei mir irgendwie nicht
Danke im Voraus.
LG Dani
I know that the developer of the Tuya Zigbee is working on the app for the bridge. I have no information on the other Tuya apps.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or canāt communicate in English then please check out Non-English boards/categories:
Please translate your post.
fe here:
Hi Dani,
Iām using the tuya cloud app. So first you need to connect them to the tuya app on your phone, than configure the tuya cloud app on homey, and add the devicesā¦
Did you tried that?
Cheers,
Marcel
I got all LSC lamps connect except the filament E27 bulbs, any idea how to get them into homey? I always get ādata property emptyā
As far as I can remember about this tuya app, you can now only work with scenes. So you donāt add the devices to homey, but using flows you can start scenes you made in the tuya app on your phone. So make a scene that turns the light on, and a scene to turn the device off.
