[APP][Pro] Panasonic Aquarea (Community)
This app makes Homey support Panasonic Aquarea devices ! If your device is not working properly with the app or if you find any issues, please leave a comment.
Supported devices:
  • Panasonic Aquarea Heat Pump
  • Panasonic Tank all in one
Thanks for all the help/support.
Live version : Panasonic Aquarea | Homey
Test version: Panasonic Aquarea (Community) | Homey
Github: GitHub - mathieuChamois/com.panasonic.aquarea.community: Pilotage des pompes à chaleur air/eau et eau/eau Panasonic Aquarea depuis Homey, via le service web Aquarea Smart Cloud · GitHub
My heatpump Panasonic M-serie T-cap is visible !!!
How can I be at your assistence or supplying info/help anyway?
Great Job, :ok_hand:
Good news! First, we need to make sure the features I added to the app work properly. I tried to be as thorough as possible with my Panasonic equipment. So first, let me make sure everything works, and then we can look into improvements. The main challenge is Panasonic’s API limit, which forces us to make a call at most once every 3 minutes.
Understandable, I will follow your work at close range.
Good work :partying_face::grinning_face: I also wish to see energy consumption. Thank you so much. Finally after all these years!!
Great progress, very prommesing! :smiley: :ok_hand:
i opened a PR to add more sensors/values;
i will try it thanks
FYI, the app is now certified and you no longer need to stay on the test version, as a live version is available (unless you want to test new features in advance).
I’ve added the features developed by CharlieRoot — thanks a lot for the contribution!
The next step will be to add the convectors directly into this app so you can control the entire system without using two Panasonic apps.
Hi everyone,
I have just released a new update that allows connecting the convectors from the Aquarea Home app. Please let me know if it works for those of you who use it.
In parallel, a user informed me that the Comfort Cloud app does not only handle the heat pump and the tank, but also supports convectors.
If this is also the case for some of you, it means I will need to expand the Comfort Cloud driver to support devices other than heat pumps and tanks. Since I do not own this hardware, I will be developing these features blindly.
I will therefore need your feedback on test versions. Please let me know if you are affected and available to help with testing.
Have a nice day.
As said before, willing to assist you in anyway.
I’m looking forward to Quit Mode/Holiday/Power Mode settings.
A new test version is available with these three modes. I’m not sure if it works yet, so I’ll let you test it and let me know.
Great job!
All three modes are working, next step is the possibility to interact/change them invidually.
Can you be more specific about changing them individually? You can do this in the third tab, where Operation Mode is located.
Hoi Matieu,
You’re absolutely right about change these Mode’s individually in the third tab, but thats not what I ment.
I was hoping for specific Flow cards. Especially the Then cards.
I’ve created a new test version with flow cards. Hope it works for you !
Great development, all 3 mode-settings are available. My Aquarea M-erie T-cap reacts fast.
For this moment I do have 1other question: I’m missing the Temp Zone Setpoint setting.
These are the basics of the FE Panasonic Heatpump (Dutch)
And a suggestion, change the name of the Card Thermostat Mode into Operation Mode
OK, I made another test version. You can try it out and let me know what you think.
Send you a PM, with PDF.
Hi everyone,
​I’ve just installed the app and successfully connected my Panasonic air-to-water heat pump. Everything is working great so far!
​Would it be possible to add a dedicated “Domestic Hot Water” (DHW) mode as a standalone option in a future update?
​Thanks for the great work!
