Hey guys, after my first app, the F1 Tracker Pro i didn’t waste to much time and build my second app, and now its time for testing.
I made an app where you can build advanced flows by telling the app what you want in natural language. AI Takes your input and builds the advanced flow for you.
What it does
You type or say (with ios shortcuts / Android) what you want the flow to do, and the app builds it for you. The flow will be disabled at first, so you can first review it, maybe do some manual edits and if you approve you enable the flow. So nothing crazy happens if AI makes something up that you don’t want.
You enter the prompt in 1 of 3 ways;
- In the settings there is a textfield where you can enter what you want (dutch or english)
- You can create a advance flow and place the card where you also can enter a prompt or connect a webhook and use shortcuts for example to enter the prompt with voice (which is the 3rd way.
What it needs
It needs an API Key from one of the AI services out there, it supports Anthropic, OpenAI and Gemini. And you need to create a homey API Key to give the app access to the advanced flows.
What it sees
The app registeres all your cards, variables and apps and uses this to build the advanced flows, of course all locally.
What i need
Its time for testing, i need some peeps to try out the app, and provide feedback where feedback is needed, try to break it, try to use it, try to give it a hard time and lemme know if there are any issues anywhere.
Lemme know what you think, thanks for testing!
p.s. note that the app hasn’t been reviewed by Athom yet, since this is still in testing phase.
