[APP][Pro] Elaway
Elaway
Control your Elaway EV charger with Homey via the Elaway cloud API.
Setup
  1. Install the app from the Homey App Store
  2. Add a device and select Elaway > Wallbox
  3. Select your region, enter your email and password, and log in
  4. Select your wallbox from the list
Only email/password login is supported. Third-party login (Google, Apple, etc.) is not supported.
Features
  • Charging control - start and stop charging sessions from Homey or through voice commands
  • Power monitoring - see real-time power usage and total energy consumed
  • Cost tracking - view the charging cost per session and total charging cost
  • Price automation - use the “Electricity price changes” flow trigger to automate charging around electricity prices (includes current and next price tokens)
Would it be possible to add Norway as a region?
Yes absolutely, reaching out to you for more information.
Version 1.0.3 now supports both Denmark and Norway too.
Hi, does the api allow for locking and unlocking the cable from the charger? This would be a great feature.
Great idea, I’ve added it and it’s available in test until published Elaway | Homey
Amazing! Thanks for the quick response. I tested it now, but i got this error:
Maybe its because the cable is still connected to the car? I will test it tomorrow after i have taken out the cable aswell.
What brand of wallbox is it? I just tested with my zaptec and it works fine. Do you have more than 1 wallbox connected to your account?
Its Zaptec! Only 1 wallbox connected.
Is it controllable now ? If not, verify it’s not actively charging while changing the lock
It works now! Thanks alot!
Was it because of that you were actively charging?
My guess is that it was because it was plugged in. It was not in a charging state when i tested it yesterday. But i had connected it earlier that day and it charged up to 80% before the car stopped it. Maybe this has something to do with it. When it was unplugged from the car the functionality worked right away. (Very quickly aswell!!)
Mine worked while plugged in but not charging, I’ll add a block for the method if state is charging
Sounds good, probably for the best.
Heads-up that may affect this app: Elaway and Aneo Mobility have merged and are now operating as Joulia. Customers are being migrated onto Joulia’s common platform right now.
I got the migration email on 27 August (Swedish account, Zaptec wallbox in a housing association). It says my association will be moved over within 14 days, and — the important part for this app — that I will lose my Elaway app login and need to set a new password for the Joulia Charge app instead. Billing also changes from card to monthly invoicing.
Since this app authenticates against the Elaway cloud API with email/password, I’d expect the login to stop working once an account is migrated, and possibly the whole API endpoint to change.
Have you had any migration notice on your account yet, or looked at whether Joulia exposes the same API? Happy to help test once mine is moved over — I can report back on what breaks and share whatever I can see from the Joulia app side. I run the charger through Homey for spot-price automation, so I have a strong interest in this not going dark.
Contact address they gave for questions is kontakt@joulia.io.
Thanks for the heads up, I’m aware of the merger but I still haven’t received anything that my account (and our housing association) is being migrated just yet.
Hopefully I receive it soon enough so I can prepare for the migration.
I got migrated now, and the connection to my wallbox died.
I just got migrated too, I’ll look into it
