I would like to manually bend the lines between flow cards. Maby add bend points where extra bends is added. It could be like a dot with a minus on hover to remove the if needed
You can us the āanyā condition to make the curve go around a bit better..
Yes I have used Any for this but would like som more control of the lines then today. And not to have to use Any for things it not should be used for.
It looks great and this is the order I want, but when trying to control sunroof and battery it gets so complex and lines goes everywhere ![]()
"d like to but the flow that I showed a part of has a string of up to 16 (!) cards.
The flow somtimes splits up on a comparison or requirement, then comeās back to the āmainā line, sometimes after 1 or 2, sometimes after 3 or 4 cards.
Each of the has to come back to the end of the flow where a command gets executed after all the calculations are done and requirement are met.
Oh well, might as well show you, it becomes unreadable because of the zoom anyway ![]()
btw, your horror-flow is easely fixed : move all to the left and put an ANY in front and separate the two colums moreā¦
Ok, other example, more to your liking I think :
Thereās another half-a-page under thatā¦
