A cry for help - (DIY) roller blind/shade
Does anybody know what the maximum size of roller blind would be to work with this motion blinds motor? Or can somebody just confirm it will work with a 2.30m width, 1.70m long blind?
Looks very promising this setup :slight_smile:
The manual does not state any limits. longest i have is 2.20m, about 1.60 high, no problem whatsoever. 2.30 together with the 1.70 I think it should manage just fine.
The biggest consideration is that longer blinds usually have wider tubes. There’s a replaceable cap that should fit snugly in the tube with enough friction so it will drive the tube. There are two versions provided in the box, one that fits 25mm tubes with ridges inside and a rubber one that is more versatile.
I do not know if other sizes are on offer. Robbshop says on their website they may even help with different sizes using a 3D printer. I cheated with the bigger blind by placing strong linnen tape over the rubber one, tight enough so it won’t slip, but that may not last forever of course. But the rubber ensures the tight fit well up to now. I think with the rubber it might even be better than a 3d printed one.
Thanks for the extensive reply Edwin. This gives me good faith to try a set :smiley:
The tube I have is 28mm inside, so I think that will be fine. That was my whole issue when trying other motors (somfy amongst others) they don’t fit as the tube was too narrow.
I will remember the tape trick if needed, and when everything works fine, I can always 3D print another connector when needed.
One more question (for now :stuck_out_tongue: ), This bridge has an USB port. Does it mean I need to connect it to a USB charger in a 230V power outlet? Or does it just a separate adapter and is the USB only to connect to a computer (for firmware flashing or something)?
No, it’s just for power, firmware is checked through the app so I’m assuming the app can upload that if needed. But anyhow, for normal day to day use you don’t need to have a computer, nas or raspberry or anything running. It’s just usb powered. Any adapter lying around will do.
Perfect, I will have some adapters lying around. Motor and bridge and remote are ordered, project for the weekend to make it work :smiley:
Don’t hesitate to ask if you need help.
I will, and I will drop a message over here when it works
There’s also an “official” thread for the app: [APP] Motion Blinds that’s high on my watch list.
As promised, a conformation it works. And is more than strong enough for my large curtain.
When I opened the box I thought, no way this is gonna be strong enough. But it works very smoothly and seems not even close to the limit of the motor.
I’m very happy with the result now.
Needed to do the tape trick to thicken the motor parts, I think I will have some better connectors 3D printed in the near future to make it perfect
I got in touch with the manufacturer to make sure, but your blinds are indeed within specs. It’s a stong little bugger indeed :muscle: Tanks for the feedback, and have fun with it!
