I have a flow for roller blinds on 3 windows that are controlled by 1 light sensor.
I would like to improve my current flow and need some help/tips!
Current flow
I light sensor is positioned next to my OLED TV that I want to protect from direct sunlight coming from 3 windows next to it.
The first window from which the light hits the TV/Sensor is Window C followed by Window B and then Window A.
As the suns position differs depending of time of year I use Sun Events instead of time.
So if it is before Solar Noon and the sensor is triggered then Window C closes.
If it is after Solar Noon (with a delay) then Window B closes. And if Window C is open (might have been cloudy before) it closes both Window B and Window C. Then it continues the same for Window A.
Improvement
What I want to improve with the flow is when/how the windows open again if it gets cloudy. As it is now the windows only open when it´s afternoon. I want them to open earlier if it gets cloudy.
Any pointers or ideas how I can accomplish this?
I can´t make it so that if the light is below X amount it should open the windows because it might be that it is sunny outside but low light because of the blinds being closed.
