The Widget Exchange(r) - Exchange Your Widget Templates with Others!
This topic is ONLY for sharing Chronograph widget templates.
This is not a support topic. For questions about Chronograph or any of its widgets, please use the Chronograph topic.
The Widget Exchange(r) is where you can share, browse, preview, and import custom Chronograph widget designs and themes. A template can contain a design, a theme, or both.
How to post a template
In Chronograph’s app settings, open Widgets → Templates → Export.
Select a saved custom design and/or theme. To share a built-in design or theme, copy it first.
Click Create TWF. Chronograph generates the TWF and example images showing the design across widget sizes, types, and states. The post and image are copied automatically.
Click Post on Forum to open The Widget Exchange(r).
In the forum composer, switch to the rich-text editor using the A beside the editor switch. This is needed to include the generated image.
Paste once, edit the description, and wait for the image upload to finish before posting.
How to use a template
In Chronograph’s app settings, open Widgets → Templates and browse the community catalog. You can search and sort templates, preview them, and open their forum posts. Click a preview image to zoom in.
Select a template and click Import.
Review the template and choose whether to import its design, theme, or both. Adjust their names if you like, then save.
The saved design and/or theme will be available to use with your Chronograph widgets. Browsing the catalog alone doesn’t save a template to Homey.
Apps
Support development
Enjoying The Widget Exchange(r)? Donations and sponsorship help support continued development. Thank you!
