Hi everyone,
Homematic IP Cloud brings your Homematic IP devices straight into Homey - no Home Assistant, no Homebridge, no extra server.
With this app, Homey connects directly to your Homematic IP access point via the Homematic IP cloud - just like the official Homematic IP app does. Home Assistant in between is no longer necessary.
Why you’ll like it
Direct connection - Homey talks to the Homematic IP cloud itself. One system less to run and maintain.
- Real time - flip a wall switch or change something in the Homematic IP app and Homey shows it right away.
- Set up in a minute - enter the SGTIN from the back of your access point, press the blue button twice, done.
- Fits right into Homey - Flows, Energy (power and kWh per switch), zones and Apple Home via Homey’s Matter bridge.
- Smart detection - devices are recognised by their function, so similar models work too.
- English and German
Switch actuators with metering (e.g. HmIP-BSM, HmIP-FSM)
- Dimmers (HmIP-BDT)
- Radiator thermostats (HmIP-eTRV-E)
- Motion and presence detectors (HmIP-SMI55, HmIP-SPI)
Running at my place
10 lights (6 switch actuators, 4 dimmers), 2 motion/presence detectors and a radiator thermostat - all moved over from Home Assistant, including my Flows and Apple Home via Matter. Home Assistant is no longer needed for Homematic IP here.
Try it (test version)
Feedback and requests for other Homematic IP devices are very welcome!
What you need: a Homematic IP Access Point that is already set up in the Homematic IP app. (The CCU / RaspberryMatic is a different system and is not supported.)
This is a community app, not an official app from eQ-3, the maker of Homematic IP.
