[APP][Pro] AlphaESS Modbus - local control of your AlphaESS home battery
AlphaESS Modbus controls and monitors an AlphaESS home battery from Homey, entirely locally over Modbus TCP. No cloud, no AlphaCloud account needed.
[App Store link]
What you get
Two devices per system
  • Home battery: charge level, battery power, energy charged/discharged, grid power and energy, max. cell temperature, battery health, inverter state, fault alarm. Shows up as a home battery in Homey Energy.
  • Solar panels: power, energy today and total generated, for the PV connected to the AlphaESS. Shows up as solar panels in Homey Energy.
Both share one Modbus connection.
Battery modes, chosen on the device or by Flow:
Mode What the battery does
Stop No charging or discharging. The home runs on the grid, solar surplus goes to the grid.
Discharge (power, target %) Discharges at a fixed power down to the target, regardless of home usage. Then waits for a new command.
Self-consumption, no charging (min %) Only covers home usage, down to the minimum. Solar surplus goes to the grid.
Self-consumption (min %, max %) Keeps the grid at zero both ways: stores solar surplus up to the maximum, covers home usage down to the minimum.
Self-consumption, no discharging (max %) Only stores solar surplus, up to the maximum. The home runs on the grid when solar is not sufficient.
Charge (power, target %) Charges at a fixed power (grid + solar) up to the target. Then waits for a new command.
Max charge (target %) Charges at full power from the grid, e.g. at negative prices. Solar on the AlphaESS is switched off.
Automatic (AlphaESS) Hands control back to the AlphaESS itself.
The modes are built for energy planners (dynamic tariffs): every mode has a language-independent name (STOP, ONTLADEN, NOM_NIET_LADEN, NOM, NOM_NIET_ONTLADEN, LADEN, MAX_LADEN, AUTO) and there is a Flow card that takes the mode as text, so tokens from a planner can be passed on directly.
  • Actions: one card per mode, a “Run battery command” card with all values, solar panels on/off.
  • Triggers: battery mode changed, battery command changed (all values as tokens), target charge level reached, inverter state changed.
  • Conditions: battery mode is, value is above (charge level, battery/grid power, command values), inverter state is, solar panels are on.
Safety: every command is sent with a fallback time (default 5 minutes) and renewed while Homey is running. If Homey or the app stops, the AlphaESS returns to its own automatic mode by itself. The AlphaESS keeps guarding its own minimum charge level as well.
Requirements
  • An AlphaESS system with Modbus TCP enabled on the EMS (port 502, Modbus address 85 by default). Ask your installer if it is not enabled.
  • Homey Pro on the same network. When adding the device, the app searches your network for the AlphaESS; you can also enter the IP address yourself. If the IP address changes later, the app finds the system again by its serial number.
Tested with
SMILE-G3-T10 V1.06 with DC-coupled solar panels. Other AlphaESS household systems use the same register list and should work; please report your model here, working or not.
Good to know
  • “Self-consumption, no charging” and “no discharging”, and the limits of “Self-consumption”, are regulated by the app every few seconds from the grid and battery power (the AlphaESS has no native mode for these). A small grid target can be set in the device settings.
  • Homey shows only one slider per device: that is the target charge level. Power and min/max levels are in the device settings (and set by the Flow cards).
  • Mode changes are listed in the device’s activity list.
Questions and bug reports in this topic. If you like the app, the donate button on the App Store page is much appreciated.
This app is not affiliated with or endorsed by AlphaESS.
:netherlands: Nederlandse samenvatting
AlphaESS Modbus bedient en monitort je AlphaESS-thuisbatterij vanuit Homey, volledig lokaal via Modbus TCP, zonder cloud.
  • Twee apparaten: een thuisaccu (laadniveau, vermogen, energie, netvermogen, accugezondheid, omvormerstatus) en de zonnepanelen op de AlphaESS (vermogen, vandaag, totaal). Beide verschijnen in Homey Energie.
  • Modi: Stop, Ontladen, NOM niet laden, NOM (nul-op-de-meter), NOM niet ontladen, Laden, Max laden en Automatisch (AlphaESS). Te kiezen op het apparaat of via Flow.
  • Voor dynamische tarieven: elke modus heeft een vaste naam (STOP, ONTLADEN, NOM_NIET_LADEN, NOM, NOM_NIET_ONTLADEN, LADEN, MAX_LADEN, AUTO), en een Flowkaart neemt de modus als tekst over, zodat je de tokens van een energieplanner direct kunt doorgeven.
  • Veilig: elke opdracht heeft een terugvaltijd (standaard 5 minuten). Stopt Homey of de app, dan gaat de AlphaESS vanzelf terug naar zijn eigen automatische modus. Ook de eigen minimale SOC van de AlphaESS blijft gelden.
  • Nodig: Modbus TCP aan op de EMS (poort 502, Modbus-adres 85). Vraag je installateur als dat nog niet aan staat. De app zoekt de AlphaESS zelf op je netwerk.
Vragen en meldingen mogen ook in het Nederlands in dit topic.
What is the difference with this existing AlphaESS modbus app? Might be worth mentioning in your post
