[APP][PRO] Laundry Tracking
I created this app to add a widget view of your Washing Machine & Tumble Dryer in cycle mode or afterwards with a traffic light warning colour scheme and a 1 hour countdown in-between.
Using the included Flow cards add to your existing flows whether using Vibration sensors or energy monitoring plugs/sockets on your dumb appliances to start and stop the timer widgets. these also feature override switches for direct widget control.
I hope these help and please provide any feedback or feature requests.
Now verified and in the App Store, thank you to everyone who has installed it. Please let me know how this is working for you.
**Laundry Tracker 1.2.0 – now in six languages**
Laundry Tracker now speaks Dutch, German, French, Spanish and Italian as well as English. The widgets, Flow cards and app description all follow the language set on your Homey, so there’s nothing to change in the app itself.
What’s translated:
- **Widgets** – the appliance name, status line, countdown badge and button (Start, Cancel, Empty)
- **Flow cards** – setting the status, checking whether a machine is running, finished or idle, the “started” and “emptied from widget” triggers, and the 1- and 2-hour waiting reminders
- **App Store page** – the description and release notes
Your existing Flows and widget status carry over as they are. There’s nothing to set up again.
The translations are new, so if you use Homey in one of these languages and something reads oddly or a term isn’t what you’d say at home, please reply here with the fix. Corrections from native speakers are very welcome.
The update will roll out once Athom has approved it.
**:netherlands: Nederlands**
Laundry Tracker is nu ook in het Nederlands beschikbaar. De widgets, Flow-kaarten en de app-beschrijving volgen de taal van je Homey; je hoeft niets in te stellen. De knoppen op de widget heten nu Start, Stop en Legen. Je bestaande Flows blijven gewoon werken. Klinkt iets vreemd of zou je het anders zeggen? Laat het hier weten, dan pas ik het aan.
**:germany: Deutsch**
Laundry Tracker gibt es jetzt auch auf Deutsch. Widgets, Flow-Karten und App-Beschreibung folgen der Sprache deines Homey, du musst nichts einstellen. Die Tasten im Widget heißen jetzt Start, Abbrechen und Ausräumen. Deine bestehenden Flows funktionieren weiter wie bisher. Klingt etwas komisch oder würdest du es anders sagen? Schreib es gern hier, dann passe ich es an.
**:france: Français**
Laundry Tracker est désormais disponible en français. Les widgets, les cartes Flow et la description de l’app suivent la langue de votre Homey, sans aucun réglage. Les boutons du widget s’appellent maintenant Démarrer, Annuler et Vider. Vos Flows existants continuent de fonctionner. Une formulation vous semble étrange ou vous diriez autrement ? Dites-le ici et je la corrigerai.
**:spain: Español**
Laundry Tracker ya está disponible en español. Los widgets, las tarjetas de Flow y la descripción de la app siguen el idioma de tu Homey, sin tener que configurar nada. Los botones del widget ahora son Iniciar, Cancelar y Vaciar. Tus Flows actuales siguen funcionando igual. ¿Algo suena raro o lo dirías de otra forma? Coméntalo aquí y lo corrijo.
**:italy: Italiano**
Laundry Tracker ora è disponibile anche in italiano. I widget, le schede Flow e la descrizione dell’app seguono la lingua del tuo Homey, senza bisogno di impostazioni. I pulsanti del widget ora si chiamano Avvia, Annulla e Svuota. I tuoi Flow esistenti continuano a funzionare. Qualcosa suona strano o lo diresti in un altro modo? Scrivilo qui e lo correggo.
Laundry Tracker v1.3.0, choose your own cycle colour :artist_palette:
Hi all,
A small update for Laundry Tracker this time, but one I think a few of you will like? Until now the widget turned blue whilst a cycle was running, and that was that. Blue is still the default, but you can now pick your own colour!
To change it, edit the Washing Machine or Tumble Dryer widget on your dashboard and you’ll find a new Cycle colour setting. Choose from Blue, Indigo, Purple, Pink, Teal, Cyan or Slate, or pick Custom and type in your own hex code (e.g. #ff8800) if you want it to match the rest of your dashboard exactly. Each widget has its own setting, so the washer & dryer can be different colours if you fancy.
I’ve left green, amber & red off the list on purpose, as those are still used for the finished, waiting & needs emptying states, and I didn’t want anyone thinking their washing was done when it isn’t!
I did try to get a little colour square next to each choice, but Homey’s widget settings only do text, so names it is…
If you already have the widget on a dashboard, you may need to remove it and add it again before the new setting shows up.
As always, any problems or ideas, let me know here?
Currently on the Test Channel (Awaiting Certification):
Laundry Tracker v1.4.0, instant updates & a cycle timer :stopwatch:
Hi all,
Another update for Laundry Tracker, and this one’s been bugging me for a while! If you use a smart plug or vibration sensor to set the status, the widget could take up to 15 seconds to catch up, so you’d be stood there waiting for it to go green. Not anymore, the widget now changes the moment the status does, whether that’s from a Flow, the widget button or one of the reminders.
The badge also now shows how long a cycle has been running. Underneath Running you’ll see the time counting up, minutes and seconds for the first hour, then hours and minutes after that, so you know roughly how long is left without going and looking at the machine.
If a cycle was already running when you update, it’ll just say Running until the next one starts, as the app didn’t know the start time before.
v1.4.0 is in the test channel now if you want to try it first, and it’s been sent to Athom for certification, so it should be live for everyone soon.
Laundry Tracker v1.5.0, a bigger widget for your dashboard :basket:
Hi all,
A big thank you to @Drako74 for this one! The double height widget in Bin Collection was their suggestion, and it went down so well I couldn’t leave the laundry widgets out could I? So v1.5.0 adds a new Size setting to both the Washing Machine and Tumble Dryer widgets. Not quite as big as the bins this time, the Large size is 50% taller, which felt about right for something you glance at while walking past.
Large gives you a bigger appliance picture and larger text, and the badge & button move underneath the title so nothing gets squashed on a narrower dashboard. Everything else works exactly the same, the traffic light colours, the running timer and your own cycle colour all carry over.
To switch, edit the widget on your dashboard and change Size from Standard to Large. Standard is still the default, so nothing changes unless you want it to.
v1.5.0 is in the test channel now if you want to try it first, and it’s been sent to Athom for certification. Fingers crossed it’s as quick as last time, 1.4.0 was through in under 24 hours!
Nice app!
Suggestion: A generic tracker for any machine? I have a washing machine and a tumble dryer but I have also a laundry dehumidifier. When the laundry is dry, the air humidity down to 40%, I consider the cycle is completed. Maybe it could be a third type that is generic and for various purposes, with free naming and Homey standard symbols or none.
@Morgan thank you so much for the suggestion! A laundry dehumidifier is exactly the kind of thing Laundry Tracker’s good at. It got me thinking about dishwashers too, so I’ve built it!
Laundry Tracker v1.6.0, track your own appliances :tada:
Hi all,
This update adds a new Custom Appliance widget, for anything that isn’t a washing machine or tumble dryer. You give it your own name and pick an icon: dehumidifier, dishwasher, clothes airer, heated airer, a plug for anything else, or no icon at all. You can have up to three of them, and each one gets its own Flow cards, so you set the status the same way as the washer & dryer.
Morgan, for your dehumidifier the Flow would be something like: when the humidity drops below 40%, set Laundry Dehumidifier to Finished. Then you get the same green, amber & red traffic light and the 1 and 2 hour reminders, and the button says Done in place of Empty.
All the usual settings are there too, Large size, your own cycle colour and the running timer.
I’ve also added a donate button to the app page. No pressure at all, but if Laundry Tracker has saved you a soggy load or two and you’d like to buy me a coffee, it’s there :hot_beverage:
v1.6.0 is in the test channel now if you want to try it first, and it’s been sent to Athom for certification, so it should be live for everyone soon.
v1.6.0 is now live for everyone! You can add the new Custom Appliance widget for your dehumidifier, dishwasher or airer straight away, no need for the test channel. A big thank you to everyone who’s tried the test versions, sent in ideas and reported bugs, especially @Morgan for this one. Your support really does keep me building, so keep the suggestions coming?
