BLUETTI for Homey
Community app to monitor and control BLUETTI power stations from Homey — over the network, from anywhere.
Install (test version): BLUETTI | Homey
Tested with: BLUETTI Elite 30 V2 only.
Other models that work with the BLUETTI cloud (AC200L, AC300, AC500, Apex 300, Elite 100/200 V2, AORA, EP760 …) may work, but are untested. Reports are very welcome!This is a community app — not made or supported by BLUETTI.
Features
- Battery level (battery tab + sensor tile)
- Solar input, grid input, AC output and DC output power
- Battery power (positive = charging, negative = discharging)
- Time to empty / time to full in readable form (“1d 9h 6m”)
- Working mode: Standard UPS, PV Priority UPS, Time Control UPS, Custom UPS
- AC output, DC output, AC ECO and DC ECO on/off — on one screen and in Flows
- Real-time updates: changes made on the unit or in the BLUETTI app appear in Homey within seconds
- When: an output was turned on/off · went offline · came back online
- And: an output is on/off
- Then: turn an output on/off
How it works
BLUETTI power stations have no local network API (all ports closed), so the app uses the same BLUETTI cloud API as the official Home Assistant integration. You sign in with your BLUETTI account inside the Homey pairing screen — your password goes to BLUETTI only, Homey just receives a login token.
Requirements: power station already set up on Wi‑Fi with the BLUETTI app, and a BLUETTI account.
Not available (not offered by the BLUETTI cloud to third-party apps): charging mode, Power Lifting, SOC limits, auto-sleep, display settings.
Other models? Help wanted
If you own another model: install the app, add your power station and post your model + a screenshot. If the log shows lines like Unmapped fnCode …, please share them — that’s how support for more data/models gets added.
Links
- Install (test): BLUETTI | Homey
- Source / issues: GitHub - gpmachado/com.gpm.bluetti: Homey app for BLUETTI power stations (cloud). Community app, tested with Elite 30 V2. · GitHub
Credits: based on the official BLUETTI Home Assistant integration and the ioBroker.bluetti adapter (both MIT).
