[APP][Pro] UNAS Monitor
UNAS Monitor
A NAS earns its keep by being forgettable. The shares mount, the backups run, and nothing asks for your attention until the morning a disk has already gone. UNAS Monitor puts the inside of the box on your dashboard so that morning comes with some warning: the state of the array, and for every disk its temperature, its health score, and the day its first bad sector appears.
It reads your Ubiquiti UNAS directly on the local network. The array becomes one device, and every disk becomes its own device, which matters more than it sounds. Homey then keeps a separate Insights curve for each bay, so you can see that bay 3 has been running two degrees warmer than its neighbours since July, and a Flow can name the disk that worries you instead of saying “something is wrong with the NAS”.
What the array reports
Capability What it tells you
Array state Fully operational, or what it has degraded to
Array usage How full it is, in per cent
Free space What is left, in TB
Disks How many the array holds
Temperature Of the appliance itself
Processor load In per cent
Memory used In per cent
Read and Write Disk throughput, in MB/s
Network in and Network out Link throughput, in MB/s
Array degraded Alarm, raised the moment the array stops being fully operational
Array almost full Alarm, raised above the threshold you set
What each disk reports
Disk state Optimal, or whatever the console now calls it
Temperature In degrees, per bay
Health score As the console computes it
Power-on hours How long this disk has been spinning
Bad sectors How many it has lost
Read and Write Throughput for this disk alone, in MB/s
Disk not optimal Alarm, on any of the four grounds below
The disk alarm rises on four separate grounds rather than one: a state that is no longer optimal, a temperature above your threshold, the very first bad sector, or a health score that has started to slip. The first bad sector is the one worth waking up for, because a disk rarely loses exactly one.
Six triggers and four conditions. No actions: the app watches, it does not touch your storage.
Triggers:
  • The array leaves the fully operational state
  • Array usage rises above a threshold you set on the card
  • The processor rises above a threshold you set on the card
  • The disk leaves the optimal state, for one named disk
  • The disk rises above a temperature you set on the card, for one named disk
  • A bad sector appears, for one named disk
Conditions:
  • The array is, or is not, fully operational
  • Array usage is, or is not, above a threshold
  • The disk is, or is not, optimal
  • The disk is, or is not, hotter than a temperature you set
Thresholds live on the Flow card rather than on the device, so one disk can feed three Flows set at forty-five, fifty and fifty-five degrees without any of them fighting over a single setting.
Widgets
Two of them, Disk array and Disks. Each takes a background: Night, Slate or Plum.
Settings
Setting Where it lives Default
Refresh interval On the array 300 seconds
Array usage threshold On the array 85 per cent
Disk temperature threshold On each disk 50 degrees
The array polls once for everybody. A four bay machine makes three calls per cycle rather than fifteen, because the disks read the same answer the array has just fetched.
An API key, and nothing else
No account, no cloud, no port forwarding. Create a key on your console under Control Plane, Integrations, Create New API Key, then pair the array with the console address and that key. The disks are discovered from the array, so you never type anything twice.
If you rotate the key later, use Repair on the array rather than deleting it. The device keeps its identity and its Flows, and the new key replaces the old one in place. The key is stored with the array and is deleted along with it.
Everything stays on your network. The console sits on your LAN, the key is only good for that console, and nothing is sent anywhere.
Which models
Written for the whole range rather than for one box. Ubiquiti sells two, four, seven and eight bay models, and nothing is assumed about how many pools you have created or how many disks sit in each: the app reads every pool and attaches its own disks to it. Empty bays are recognised as empty rather than counted as failed disks.
Languages
English, French, German, Spanish, Italian, Dutch, Polish, Danish.
Reporting a problem
Post here with your Homey firmware version, the app version, your UNAS model, and how many bays are populated. A screenshot of the device page helps more than a description. If pairing is what fails, the error message is the useful part: it says whether the console could not be reached at all or whether the key was refused, and those two send you to very different places.
Feedback and testers welcome.
Have fun :wink:
UNAS Monitor 1.2.0 is out. So far the app told you how your UNAS is doing. It now tells you how it has been doing.
The console keeps no history the app can read, so the app keeps its own: a reading every five minutes over the last 24 hours, one point a day of fill level for 90 days, and the last 40 events. It lives on your Homey and survives a restart.
Six new widgets, next to Disk array and Disks:
  • Fill trend, the array’s fill level over 7, 30 or 90 days and, if the trend holds, how many days until it is full. Not a prophecy, a ruler laid along the curve, and beyond ten years it does not pretend to give a date.
  • Disk temperatures, one curve per bay, the lowest and highest of the period, and a dashed line at 50 °C.
  • Disk activity, read and write throughput, with the averages and the peak.
  • Network, received and sent.
  • Processor and memory, load, processor temperature and memory use.
  • Event log, status changes, rebuilds, disks added, removed or running hot, console outages.
The short-term ones show 6, 12 or 24 hours. All eight tiles now share one layout: category, NAS name, main value, details. Five backgrounds: Deep blue, Slate, Plum, Forest and Sand.
How to use: add a widget from the dashboard, pick your NAS in the Console list (leave it empty for the first one), then the period and a background. Right after the update the curves are empty: they need a few minutes of readings before there is anything to draw. Give the fill trend a few days before you believe its date.
More about the app, every widget and Flow card included: UNAS Monitor for Homey — Rapinology
Feedback welcome.
Have fun :wink:
UNAS Monitor 1.3.0 is out. It started with a report from a UNAS 2 owner: every indicator except the temperature showed Homey’s dotted placeholder. That is fixed, and since an update was due anyway, it brings quite a bit more.
Icons
  • Every indicator now has its own icon.
  • Each NAS model gets its own device icon, picked from the enclosure when you pair it: UNAS 2, UNAS 4, UNAS Pro 4, UNAS Pro and UNAS Pro 8. Homey keeps the icon of a device that is already paired, so you will only see yours after adding the NAS again. If you own one of these models and pair it, please tell me whether the right icon shows up: I could only check the UNAS Pro myself.
13 new Flow cards
  • When: the array starts or finishes rebuilding, a data integrity check starts or ends, the NAS has restarted, its firmware has been updated, a network port goes up or down, the NAS stops responding, the NAS responds again, a disk reports new SMART errors.
  • And: the array is rebuilding, a data integrity check is running, the NAS responds.
  • Then: refresh now, to read the console right away instead of waiting for the next reading.
A few ideas: a notification when a rebuild ends; pausing heavy jobs while an integrity check runs; a push message when the NAS has not answered for a while, and another when it is back.
New indicators
  • On the NAS: uptime in days, the maintenance in progress (rebuild with its progress, or integrity check), and the date of the next integrity check.
  • In the device settings: model, firmware and UniFi Drive version for the NAS, model, serial number, firmware, bay and role for each disk.
Existing devices pick these up by themselves after the update: no need to pair again.
Three new widgets
  • Front panel, the NAS seen from the front: one drawer per bay, coloured by state, with each disk’s temperature. It follows your enclosure, two drawers on a UNAS 2, eight on a Pro 8, empty bays drawn dashed.
  • Maintenance, the date of the next integrity check, or the progress of a rebuild, with uptime and RAID level.
  • Overview, one green, amber or red light, with usage, the hottest disk and how many disks are healthy.
Like the other eight, they come with the five backgrounds: Deep blue, Slate, Plum, Forest and Sand.
Feedback welcome.
Have fun :wink:
