[APP][Pro] Joulia - EV charging for housing communities
Joulia
Control your Joulia EV charger with Homey via the Joulia cloud API.
Setup
  1. Install the app from the Homey App Store
  2. Add a device and select Joulia > Wallbox
  3. Enter your email and password, and log in
  4. Select your wallbox from the list
Only email/password login is supported. Third-party login (Google, Apple, etc.) is not supported.
Features
  • Charging control - start and stop charging sessions from Homey or through voice commands
Hi!
Wanted to let you know that i am getting Bad Request error when trying to turn off charging. And the data from the charger does not seem to update. Worked when i first installed it yesterday for starting charging. But stopped working today.
Otherwise really interested in this! Would you consider adding the ability to lock / unlock the cable to the app?
Sure, I have a bunch to add, are you somewhat active here :)?
Delete the integration and redownload it, has cable lock, live updates etc :slight_smile:
